AMMEND LISP FILE
AMMEND LISP FILE
lmoultonX6YLM
Message 1 of 8
AMMEND LISP FILE
lmoultonX6YLM
Could anyone help ammend this lips file please. Its part of a longer file.
The lisp ( i think - i'm no programmer ) looks and returns the length of pipe by its name.
It was working fine...however we have now changed the block/file name FROM Pipe Cut To 1170mm - horizontal
TO Pipe-H-1170.
Lee
code below
;;;--- Function to get the length from the block name
;;; Example Blockname = "pipe cut to 1170mm - horizontal"
;;; Returns 1170.0 as real number
(defun getLength(blkName)
(setq cnt 1 foundIt 0)
(while(< cnt (- (strlen blkName) 1))
(setq ch(substr blkName cnt 2))
(if(= ch "mm")
(setq foundIt cnt)
(setq cnt(+ cnt 1))
(if(> foundIt 0)
(progn
(setq nxtLen(substr blkName (- foundIt 2) 2))
(setq len(substr blkName (- foundIt 1) 1))
(setq incCnt 3)
(while(> (atof nxtLen) (atof len))
(setq len nxtLen)
(setq nxtlen(substr blkName (- foundit incCnt) incCnt))
(setq incCnt(+ incCnt 1))
(atof len)
Accepted solutions (3)
Replies (7)
Message 2 of 8
ВeekeeCZ
Possibly like this which works for both
(defun getLength (n) (atof (vl-list->string (vl-remove-if-not '(lambda (x) (< 47 x 58)) (vl-string->list n)))))
Message 3 of 8
lmoultonX6YLM
Thanks for the response -
i was hoping to keep the coding pretty much the same - could i just not remove / ammend certain lines
for example - would it work by just removing (if(= ch "mm") ??
That might sound stupid - but i donot understand what the code is looking for and just want to change it slightly then paste it back into the rest of lisp program. Does that make sense ?
Message 4 of 8
ВeekeeCZ
Ok, let's play your game.
The original code search for "mm" and then goes backward from it and grabs all numbers.
Now, since we don't have "mm" we don't know where the number ends. But you're saying that now you have
Pipe-H-1170.
Now see... should I search for "." instead of "mm". Or is it just your carelessness so "." really isn't there?
Or..... whatever......
I just made it my way by the clear input/output you gave me. It's a black box to you anyway.
Message 5 of 8
lmoultonX6YLM
Ah ok thanks - i understand a little more now. Great explanation thankyou.
Message 6 of 8
Sea-Haven
Pipe-HH-1170 use this returns -1170, use (abs so removes - sign.
;;-------------------=={ Parse Numbers }==--------------------;;`
;;  Parses a list of numerical values from a supplied string. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  s - String to process                                     ;;
;;  Returns:  List of numerical values found in string.       ;;
(defun LM:ParseNumbers ( s )
    (lambda ( l )
      (read
        (strcat "("
          (vl-list->string
            (mapcar
              (function
                (lambda ( a b c )
                  (if
                    (or
                      (< 47 b 58)
                      (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                      (and (= 46 b) (< 47 a 58) (< 47 c 58))
                    b 32
              (cons nil l) l (append (cdr l) (list nil))
    (vl-string->list s)
Message 7 of 8
john.uhden
Have you tried...
(getlength "Pipe-H-1170")
John F. Uhden
Message 8 of 8
Sea-Haven
; error : no function definition <GETLENGTH> ; expected FUNCTION at [eval]
