Allow end point selection during insert on this custom insert list command
- Mute
- Permalink
- Report
So I have had this lisp for awhile and now adding "sound" to the lisp. I was able to add it just fine but when it inserts the block it doesn't allow you to use object snaps to be used. Is there a way to add it see full lisp below.
I think it has to do with this section of the code but not 100% sure. I don't need it to specifically only use object snap points because sometimes I just insert the blocks in open space. I really hope this can be done it will make it a lot easier put the legend together, rather than putting all the blocks in and then move them together afterwards. I have attached 2 drawings that the lisp can reference for the blocks.
(defun MoveTo ( e pt / gr )
;;; pBe 20 March 2015 ;;;
(setq pt_ pt)
(progn
(princ "\nPick insertion point: ")
(while (= 5 (car (setq gr (grread t 13 0))))
(redraw)
(vlax-invoke e 'Move pt (cadr gr))
(grdraw pt_ (cadr gr) 1 -1)
(setq pt (cadr gr))
;;; Remove the lines below | For testing purposes only ;;;
;;; (entmakex (list (cons 0 "LINE")
;;; (cons 10 pt_)
(defun ibMain ( Det_ lst / adoc space lst leg vleg bn blk ipoint dbx blkdbx AllData ) ;;; pBe 20 March 2015 ;;; (setq adoc (vla-get-activedocument (vlax-get-acad-object)) space (vlax-get (vla-get-ActiveLayout adoc) 'Block)) (if (setq AllData nil ss (ssget (list (cons 2 (strcat (apply 'strcat (mapcar '(lambda (nme) (strcat nme ",")) (apply 'append (setq leg (mapcar 'car lst))))) "`*U*") )))) (progn (repeat (setq i (sslength ss)) (setq en (ssname ss (Setq i (1- i)))) (if (member (setq bn (vla-get-effectivename (vlax-ename->vla-object en))) (apply 'append (mapcar 'car lst))) (setq AllData (cons (list bn (cdr (assoc 10 (entget en)))) ;;; (mapcar '(lambda (d) ;;; (cdr (assoc d (entget en)))) ;;; '(2 10)) AllData) ) ) ) ;; Selection Sorted from Top to Bottom ;; (setq AllData (vl-sort AllData '(lambda (dt dt2) (> (cadadr dt)(cadadr dt2))))) ;; ;; (foreach data AllData (if (setq vleg (vl-some '(lambda (nm_) (if (member (Car data) nm_) nm_)) leg)) (foreach det (cadr (assoc vleg lst)) (if (setq bn (_BlockExist det det_ )) (progn (Setq obj (vlax-invoke space 'InsertBlock (cadr data) bn 1 1 1 0)) ;;;(vla-put-layer obj "0") to change layer to certain layer removed to keep current layer active (moveTo obj (cadr data)) (redraw) ) (princ "\n<<< Detail Not Found >>>") ) ) ) (setq leg (vl-remove vleg leg)) ) ) (princ "\n<<< Block Legend Detail not found >>>") ) (princ) (command "-purge" "blocks" "" "n") ) (defun MoveTo ( e pt / gr ) ;;; pBe 20 March 2015 ;;; (setq pt_ pt) (progn (princ "\nPick insertion point: ") (while (= 5 (car (setq gr (grread t 13 0)))) (redraw) (vlax-invoke e 'Move pt (cadr gr)) (grdraw pt_ (cadr gr) 1 -1) (setq pt (cadr gr)) ) ) ;;; Remove the lines below | For testing purposes only ;;; ;;; (entmakex (list (cons 0 "LINE") ;;; (cons 10 pt_) ;;; (cons 11 pt))) ;;; Remove The Lines above | For testing purposes only ;;; ) (defun _BlockExist (bn_ de_ / indfile f flst chk) ;;; pBe 20 March 2015 ;;; (setq flst nil) (cond ;;; Current drawing session ;;; ((or (and (tblsearch "BLOCK" de_) (tblsearch "BLOCK" bn_)) (tblsearch "BLOCK" bn_) ) bn_ ) ;;; Block saved as individual file within SFSP ;;; ((setq indfile (findfile (strcat bn_ ".dwg"))) indfile) ;;; if found, copy listed blocks from ;;; ;;; "XLS DETAILS.dwg" will only run once per ;;; ;; session if other conditions evaluates to nil ;;; ((setq f (findfile (strcat de_ ".dwg"))) (setq chk (i:openDBXDoc f)) (foreach itm (apply 'append (mapcar 'cadr lst)) (if (not (vl-catch-all-error-p (vl-catch-all-apply (function (lambda () (setq blkdbx (vla-item (vla-get-blocks chk) itm)) ) ) ) ) ) (progn (setq flst (cons itm flst)) (vla-copyobjects chk (vlax-safearray-fill (vlax-make-safearray vlax-vbObject '(0 . 0)) (list blkdbx) ) (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)) ) ) ) ) ) (setq chk (i:CloseDBXDoc chk)) (if (member bn_ flst) bn_) ) ) ) ;;; ODBX Functions Robert Bell ;;; (defun i:IsReadOnly (fileName / fileH) (cond ((setq fileH (open filename "a")) (close fileH)) ((not fileH)))) (defun i:CloseDBXDoc (dbxDoc) (vl-catch-all-apply 'vlax-Release-Object (list dbxDoc)) (setq dbdDoc nil) ) (defun i:OpenDBXDoc (fileName / newFile dbxDoc chkOpen) (cond ((or (i:IsReadOnly fileName) (= (strcase (vl-filename-extension filename)) ".DWT")) (setq newFile (vl-filename-mktemp "Temp .dwg")) (vl-file-copy fileName newFile))) (if (< (atoi (substr (getvar "ACADVER") 1 2)) 16) (setq dbxDoc (vlax-create-object "ObjectDBX.AxDbDocument")) (setq dbxDoc (vlax-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2) ) ) ) ) (setq chkOpen (vl-catch-all-apply 'vla-Open (list dbxDoc (cond (newFile) (fileName))))) (cond ((vl-catch-all-error-p chkOpen) (vlax-Release-Object dbxDoc) nil) (dbxDoc))) ;; --End of ODBX Functions : Robert Bell-- ;;; ;;; THIS IS SECTION OF THE CODE WHERE YOU ADD ;;; ;;; SYSTEM AND NAME LIST FOR LEGEND & DETAILS ;;; (defun c:ibTEST ( / lst System SysData NameList) ;; pBe 20 March 2015 ;;; ;;; This is where you add the a New System ;;; ;;; & Name list ;;; ;;; FORMAT: ("SYSTEM NAME" ( ;;; ;;; ( ("LN1" "LN2") ;<--One or more LEGEND ;;; ;;; ("D1" "D2"))) ;<--One or more DETAIL ;;; (setq NameList ;; "XLS DETAILS"" name list ;; '( ("XLS DETAILS" ( ( ("OP921-DB-11 -- LEGEND" "OOH941-DB-11 - LEGEND" "OOH941-DB-11" "HI921-DB-11" "FP-11 - DB-11") ("SMOKE AND HEAT TYPICAL DETAIL")) ( ("AS-75-R-WP") ("AS-75-R-WP DETAIL")) ( ("HI921 - DB2-HR LEGEND" "OP921-DB2-HR - LEGEND") ("OOH941-HI921- DB2-HR")) ( ("HTRI-D-LEGEND") ("HTRI-D WATER FLOW AND TAMPER" "HTRI-D BASIC DETAIL")) ( ("HTRI-S-LEGEND") ("HTRI-S-DETAIL" "HTRI-S - PIV WIRING DETAIL")) ( ("PAD-3 -- LEGEND") ("PAD-3 - DETAIL" "PAD-- RESISTOR -- DETAIL")) ( ("PAD-4-6A-LEGEND") ("PAD-4-6A-DETAIL" "PAD-- RESISTOR -- DETAIL")) ( ("PAD-4-9A -- LEGEND") ("PAD-4-9A-DETAIL" "PAD-- RESISTOR -- DETAIL")) ( ("HTRI-R-LEGEND") ("HTRI-R-DETAIL")) ( ("HMS-D-LEGEND" ) ("HMS-D-DETAIL" )) ( ("HCP -- LEGEND") ("HCP WIRING DETAIL")) ( ("FDBZ492 - OP921 - ST-50" "RSM-2" "RL-HW - LEGEND") ("FDBZ492 - RSM-2 - HTRI-R - RL-HW" "FDBZ492-HR DUCT MOUNTING DETAIL")) ( ("FDBZ492-HR - OP921 - ST-50 - DAMPER DUCT LEGEND") ("FDBZ492-HR DAMPER DUCT DETAIL" "FDBZ492-HR DUCT MOUNTING DETAIL" "XSERIES DAMPER DUCT DETECTOR DETAIL")) ( ("FDBZ492-HR - OP921 - ST-50 LEGEND" "FDBZ492-RTL -- LEGEND") ("FDBZ492-HR WITH HTRI-R AND FDBZ492-RTL - DETAIL" "FDBZ492-HR DUCT MOUNTING DETAIL")) ( ("MR-801T-LEGEND") ("HTRI SHUNT TRIP DETAIL")) ( ("HTRI-M - LEGEND") ("HTRI-M DETAIL")) ( ("MB-G10-24-R - LEGEND") ("QUAD MODULE WITH W-F AND BELL")) ( ("SEC-W -- LEGEND") ("SEC-W - DETAIL")) ( ("RSS-24MCW-ALW - LEGEND") ("RSS SERIES STROBE - DETAIL")) ( ("E50-24MCW-ALW - LEGEND" "E-50 - LEGEND") ("E-50 SERIES SPEAKER WIRING DIAGRAM - DETAIL")) ( ("MS-151") ("MS-151-DETAIL")) ( ("HMS-S - LEGEND") ("HMS-S - DETAIL")) ( ("FC922-UT LEGEND") ("FC922-UT RISER")) ( ("FC901-U3 -- LEGEND") ("FC901-U3 -- DETAIL" "FC901-U3 BACKBOX DETAIL")) ( ("HZM-LEGEND") ("HZM-BEAM DETECTOR")) ( ("SET-185-R-WP -- LEGEND" "SE-MC-W -- LEGEND" "SET-MC-CW -- LEGEND" "SET-MC-R -- LEGEND" "SET-S17-R-WP" "SE-MC-R -- LEGEND" "SE-MC-CR - LEGEND" "SE-MC-CW -- LEGEND") ("SE-MC - SET-MC SPEAKER STROBE")) ( ("ZR-MC-CW" "ZR-MC-R" "ZH-HMC-R - LEGEND" "ZR-HMC-CW - LEGEND" "ZR-HMC-R" "ZR-MC-CR - LEGEND" "ZH-MC-R-LEGEND" "ZH-MC-W -- LEGEND" "ZH-MC-CR - LEGEND" "ZH-MC-CW - LEGEND" "ZH-HMC-CW - LEGEND" "ZH-HMC-CR - LEGEND" "ZH-MC-W-LEGEND" "ZR-MC-W-LEGEND") ("ZR-MC - ZH-MC - ZR-HMC")) ( ("FDCI0422 -- LEGEND") ("FDCIO422 QUAD MODULE - TAMPER AND FLOW DETAIL" "FDCIO422 SHUNT TRIP ELEVATOR DETAIL" "FDCIO422 QUAD MODULE - FIRE PUMP DETAIL" "FDCIO422 - DETAIL")) ( ("OP921-ABHW-4B -- LEGEND") ("OP921-ABHW-4B -- DETAIL")) ( ("OOHC941-ABHW-4B - LEGEND") ("OP921-ABHW-4B -- DETAIL")) ( ("FIRE ALARM DEVICE LEGEND HEADING") ("DEVICE MOUNTING LOCATION DETAIL" "Brad's Nicet Block" "Darwins nicet stamp" "CABLE STIPPING DETAIL")) ( ("FC922-US -- LEGEND") ("FC922-US FULL PANEL -- RISER")) ( ("OSI-90 - LEGEND" "OSE-SPW - LEGEND") ("OSID-HTRI - DETAIL" "OSID-XTRI - DETAIL")) ( ("XTRI-S - LEGEND") ("XTRI-S DETAIL" "XTRI-S - PIV DETAIL")) ( ("SIGA-AA50 - LEGEND") ("AA30-AA50 - DETAIL")) ( ("XTRI-D - LEGEND") ("XTRI-D WATER FLOW AND TAMPER")) ( ("XTRI-R - LEGEND") ("XTRI-R DETAIL" "XTRI-R SHUNT TRIP DETAIL")) ( ("SLHSWW-F - LEGEND" "SLHSCR-F - LEGEND" "SLSCR-F - LEGEND" "SLSCW-F - LEGEND" "SLSWW-F - LEGEND" "SLHSWR-F - LEGEND" "SLSWR-F - LEGEND" "SLHSCW-F - LEGEND" "SLHWW-N - LEGEND") ("SL SERIES HORN-STROBE - DETAIL")) ( ("SLSPSWR-F - LEGEND" "SLSPSWW-F - LEGEND" "SLSPSCW-F - LEGEND") ("SL SERIES SPEAKER-STROBE - DETAIL")) ( ("XTRI-M - LEGEND") ("XTRI-M DETAIL")) ( ("FC924-UT - LEGEND") ("FC924-UT - RISER")) ( ("OP921-ABHW-4S - LEGEND") ("ABHW-4S - DETAIL")) ( ("MBDC-6 - LEGEND") ("MBDC-6 - DETAIL")) ( ("SLSPCW-F - LEGEND") ("SL SERIES SPEAKER WIRING DETAIL")) ( ("LSPSTRC3 - LEGEND" "LSPSTR3 - LEGEND") ("EXCEDER SPEAKER STROBE - DETAIL")) ( ("LSTR3 - LEGEND" "LSTRC3 - LEGEND" "LHSR3 - LEGEND") ("EXCEDER STROBE - DETAIL")) ( ("TSM-1X - LEGEND") ("TSM-1X DETAIL" "XSERIES DUCT DETECTOR DETAIL" )) ( ("Legend 1") ("bananaitlog")) ( ("MTH-MC-R") ( "BANANACAKE" ))) ) ;; "EDWARDS DETAIL" name list ;; ("EDWARDS DETAIL" ( ( ("SIGA-CC1S-LEGEND") ("SIGA - CC1S")) ( ("FPD-7024 - LEGEND") ("FPD-7024 - DETAIL" "FPD-7024 BACKBOX - DETAIL")) ( ("FPP-RNAC-8A-4C - LEGEND") ("FPP-RNAC-8A-4C - DETAIL")) ( ("D282A-D280A SMOKE - LEGEND") ("D280A - DETAIL")) ( ("HSR - LEGEND" "STR - LEGEND") ("HSR-STR - DETAIL")) ( ("G1F-VM - LEGEND") ("G1F-VM")) ( ("SIGA-CT1-LEGEND") ("SIGA-CT1-DETAIL" "SHUNT TRIP POWER SUPERVISION-CONTROL")) ( ("SIGA-CR-LEGEND") ("SICA-CR-DETAIL" "SIGA-CR--DAMPER RELAY HIGH VOLTAGE DETAIL" "SIGA-CR--DAMPER RELAY LOW VOLTAGE DETAIL" )) ( ("SIGA-CT2-LEGEND") ("SIGA-CT2-DETAIL")) ( ("SIGA-COD - SIGA-AB4G - LEGEND") ("SIGA-AB4G AUDIBLE BASE - DETAIL")) ( ("SIGA-SD - SD-T60 DAMPER DUCT" "SD-TRK-LEGEND") ("SIGA-SD -- DAMPER DUCT DETAIL" "DUCT DETECTOR MOUNTING DETAIL")) ( ("SIGA-SD - SD-T60" "SD-TRM LEGEND") ("SIGA-SD TYPICAL DETAIL" "DUCT DETECTOR MOUNTING DETAIL")) ( ("BPS6A-LEGEND") ("BPS6A - DETAIL" "BPS6A-CR - DETAIL" "BPS6A RESISTOR - DETAIL" "BPS6A BASIC - DETAIL")) ( ("BPS10A-LEGEND") ("BPS10A - DETAIL" "BPS10A-CR - DETAIL" "BPS6A RESISTOR - DETAIL")) ( ("757-8A-T - LEGEND") ("757-8A-T - DETAIL")) ( ("G1RF-HDVM" "G1RF-VM" "G1F-HDVM" "G4LFRF-HVM - LEGEND" "G4LFWF-HVM - LEGEND") ("G1RF MOUNTING DETAIL." "G1F-HDVM - G1F-HDVM")) ( ("GCF-VM -- LEGEND" "GCF-HDVM -- LEGEND") ("GCF-VM - DETAIL")) ( ("SIGA-HRD-SIGA-SB4 - LEGEND" "SIGA-HFS-SIGA-SB4 - LEGEND" "SIGA-PD-SIGA-SB4 -- LEGEND") ("SIGA-PD--HRD - SIGA-SB4 -- DETAIL"));;;;; ( ("SIGA-HRD-SIGA-RB4 -- LEGEND" "SIGA-PD-SIGA-RB4 -- LEGEND") ("SIGA-PD-HRD - SIGA-RB4 -- DETAIL"));;;;; ( ("SIGA-278") ("SIGA-278 - DETAIL")) ( ("SIGA-LED - LEGEND") ("SIGA-SD WITH LAMP TYPICAL DETAIL")) ( ("G4HFWF-S7VMC -- LEGEND" "WG4WA-SVMC -- LEGEND") ("G4HFWF-WG4WA -- DETAIL" "G4HFWF-S7VMC -- BOX DETAIL")) ( ("SIGA-AA50 - LEGEND" "APS6A - LEGEND") ("APS6A - DETAIL")) ( ("GCF-S7VMH - LEGEND" "G4RF-S7VM -- LEGEND" "GCF-S7VM - LEGEND") ("GCF-S7VM -- G4F-S7VM -- G4F-S7VMH DETAIL")) ( ("SIGA-270-LEGEND") ("SIGA-270-DETAIL")) ( ("FIRE ALARM DEVICE LEGEND HEADING") ("Brad's Nicet Block" "Darwins nicet stamp" "CABLE STIPPING DETAIL")) ( ("ANS25MDG2 -- LEGEND") ("ANS25-50-100 -- DETAIL")) ( ("PIV - WATERFLOW - TAMPER") ("SIGA-CT2 WITH WATERFLOW & TAMPER" "SIGA-CT1 WITH PIV")) ( ("IO1000GD -- LEGEND") ("IO1000GD - RISER"))) ) ;; "NURSE CALL" name list ;; ("NURSE CALL DETAIL" ( ( ("HC-CONSOLE-3K - LEGEND") ("HC-CONSOLE - DETAIL")) ( ("HC-CL2-3K - LEGEND") ("HC-CL2-3K - DETAIL")) ( ("HC-CCSTN-3K - LEGEND") ("HC-CCSTN-3K - DETAIL")) ( ("HC-PB3-CANCEL -REMOTE CANCEL - LEGEND") ("HC-PB3-CANCEL -REMOTE CANCEL- DETAIL")) ( ("HC-PB3-CANCEL -PUSH BUTTON- LEGEND") ("HC-PB3-CANCEL -PUSH BUTTON- DETAIL")) ( ("HC-PP2-LAV-3K - LEGEND" "HC-PP2-LAV-3K WEATHER PROOF - LEGEND") ("HC-PP2-LAV-3K - DETAIL")) ( ("HC-CL4 - LEGEND") ("HC-CL4 - DETAIL")) ( ("HC-VSTN - LEGEND") ("HC-VSTN - DETAIL")) ( ("NGGTWY2-H - LEGEND") ("NGGTWY2-H - RISER")) ( ("HC-IPSWITCH8 - LEGEND") ("HC-IPSWITCH8 - RISER")) ( ("HC-DUTY-3K - LEGEND") ("HC-DUTY-3K - DETAIL")) ( ("NGTDSP-H - LEGEND") ("NGTDSP-H - RISER")) ( ("LEGEND HEADER - NURSE CALL") ("RJ-45 PINOUT - DETAIL")) ( ("HC-PB2-CODE-3K - LEGEND") ("HC-PB2-CODE-3K - DETAIL")) ( ("HC-PB2-EMERG - LEGEND") ("HC-PB2-EMERG - DETAIL")) ( ("HC-AUX2-3K - LEGEND") ("HC-AUX2-3K - DETAIL")) ( ("SF117-2C - LEGEND") ("SF117-2C - DETAIL")) ( ("1212-WPS - LEGEND") ("1212-WPS - DETAIL")) ( ("HC-PSTN1-BED - LEGEND" "HC-PSTN2-BED - LEGEND") ("HC-PSTN1-HC-PSTN2 - DETAIL")) ( ("VER-2407 - LEGEND" "VER-2037 - LEGEND" "VER-4432 - LEGEND" "VER-4452 - LEGEND") ("IR TRACKING WIRING DETAIL" "TYPICAL IR SENSOR WIRING DETAIL"))) ) ;; "AV" name list ;; ("SOUND LEGEND" ( ( ("HD-TX-201-C-2G-E-B-T") ("HD-TX-201-C-2G-E-B-T - LEGEND")) ( ("HD-TX-101-C-1G-E-B-T") ("HD-TX-101-C-1G-E-B-T - LEGEND"))) ) ;; "xxxxxxx" name list ;; AKA NAME OF FILE ;;; ;;; ("SYSTEM NAME" ( ;;; ( ("LEGEND") ("DETAIL")) ;;; ( ("LEGEND") ("DETAIL" "DETAIL")) ;;; ( ("LEGEND" "LEGEND") ("DETAIL"))) ;;; ) ;;; ;; "xxxxxxx" name list ;; ) ) ;;; ---End of Previous Comment--- ;;; ;;; This is where you add the System name ;;; ;;; Note: Only the ONE word of the filename ;;; ;;; Example "EDWARDS DETAIL" as "EDWARDS" ;;; ;;; Example "OTHER STUFF" as "STUFF" ;;; ;;; (initget "XLS EDWARDS STUFF") ;;; ;;; Example "EMERSONS DETAILS" as "eMerson" ;;; ;;; (initget "XLS EDWARDS eMerson")<-- "M" ;;; ;;; "E" already in use for EDWARDS ;;; ;;; "\nChoos System [XLS/Edwards/eMerson]: " ;;; (initget "XLS EDWARDS NURSE SOUND") ;;; ---End of Previous Comment--- ;;; (setq System (cond ( (getkword "\nChoose System [XLS/Edwards/Nurse/Sound] <XLS>: ") ) ( "XLS" ))) (setq SysData (vl-some '(lambda (b) (if (wcmatch b (strcase (strcat "*" system "*"))) b)) (mapcar 'car NameList)) SysData (assoc SysData NameList)) (ibMain (car SysData) (cadr SysData)) ) (vl-load-com) (princ (strcat "\n:: Insert Detail From Legend Version 1.1 | pBe 2015 ::" "\n:: Type \"IB\" to Invoke ::" ) ) (princ)
