Visual LISP, AutoLISP and General Customization
Align Blocks automatically - lisp
10 REPLIES 10
Message 1 of 11
Yamishon_Noah
3399 Views, 10 Replies
Hi
I searched lot for this activity but could not find. please do the needful
I have several blocks placed in drawing but problem is these blocks overlapping slightly to another block.
I want to have lisp that will align these blocks properly. (I have to avoid overlapping).
like if I select multiple blocks then all these overlapped blocks will slightly move (any direction) to avoid overlap and re positioned.
Kindly see attached dwg, I have shown current condition and how I want output.
I have more than 100 dwgs and each have more than 150blocks like this. by manually it takes plenty of time.
10 REPLIES 10
Message 2 of 11
m_badran
in reply to: Yamishon_Noah
Hi, I think re scale the blocks is best solution for you.
Message 3 of 11
Yamishon_Noah
in reply to: m_badran
No, re-scaling shall not be done. as the block size fixed for the dwg.
One block has to see its boundary and if any other blocks overlapping then it has to move till overlapped (distant - any direction) automatically, this process shall has to execute for selected blocks or all blocks in a dwg.
I hope you will understand my query.
MK
Message 4 of 11
marko_ribar
This is my version... It is applicable only for single overlapping group and disposition is randomly processed according to disposition matrix... So your actually upper 2 blocks in my version are scattered to the right... If that's not such a problem - final disposition is scattered near center point of group so the task is solved in most situations correctly, but without checking dispositions of similar attributed blocks...
(defun c:scatterblks ( / dispositionmatrix s i m l b c k rn mn w l bp rh )
  (vl-load-com)
  (defun dispositionmatrix ( n / f k r l )
    (setq f (1+ (fix (sqrt (- n 0.5)))))
    (setq k 0)
    (repeat f
      (repeat f
        (setq k (1+ k))
        (if (<= k n)
          (setq r (cons 1 r))
          (setq r (cons 0 r))
      (setq l (cons (reverse r) l) r nil)
    (reverse l)
  (prompt "\nSelect overlapping group of blocks...")
  (setq s (ssget "_:L" '((0 . "INSERT"))))
  (if s
    (progn
      (setq i (sslength s))
      (setq m (dispositionmatrix i))
      (repeat i
        (setq l (cons (list (acet-ent-geomextents (setq b (ssname s (setq i (1- i))))) b) l))
      (setq c (mapcar (function (lambda ( x ) (/ x (length l)))) (apply (function mapcar) (cons (function +) (mapcar (function (lambda ( x y ) (mapcar (function (lambda ( a b ) (/ (+ a b) 2))) x y))) (mapcar (function caar) l) (mapcar (function cadar) l))))))
      (setq k 0)
      (foreach r m
        (foreach v r
          (if (= v 1)
            (setq rn (cons (nth k l) rn) k (1+ k))
            (setq rn (cons nil rn))
        (setq mn (cons (reverse rn) mn) rn nil)
      (setq mn (reverse mn))
      (setq w (apply (function max) (mapcar (function (lambda ( x ) (apply (function +) (mapcar (function (lambda ( y ) (abs (- (car (cadr (car y))) (car (car (car y))))))) (vl-remove (function null) x))))) mn)))
      (setq l (apply (function max) (mapcar (function (lambda ( x ) (apply (function +) (mapcar (function (lambda ( y ) (abs (- (cadr (cadr (car y))) (cadr (car (car y))))))) (vl-remove (function null) x))))) (apply (function mapcar) (cons (function list) mn)))))
      (setq bp (mapcar (function +) c (list (- (/ w 2)) (- (/ l 2)))))
      (setq rh 0.0)
      (foreach rn mn
        (setq bp (mapcar (function +) bp (list 0.0 rh)))
        (setq rh 0.0)
        (foreach vn rn
          (if vn
            (progn
              (vla-move (vlax-ename->vla-object (cadr vn)) (vlax-3d-point (caar vn)) (vlax-3d-point bp))
              (setq bp (mapcar (function +) bp (list (abs (- (car (cadr (car vn))) (car (car (car vn))))) 0.0)))
          (if (< rh (abs (- (cadr (cadr (car vn))) (cadr (car (car vn))))))
            (setq rh (abs (- (cadr (cadr (car vn))) (cadr (car (car vn))))))
        (setq bp (subst (- (car c) (/ w 2)) (car bp) bp))
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 11
marko_ribar
in reply to: marko_ribar
There was a mistake in my previously posted code... The problem was that I haven't tested it with number of blocks that isn't square root-able... This should fix this issue...
(defun c:scatterblks ( / dispositionmatrix s i m l b c k rn mn w h bp rh ) (vl-load-com) (defun dispositionmatrix ( n / f k r l ) (setq f (1+ (fix (sqrt (- n 0.5))))) (setq k 0) (repeat f (repeat f (setq k (1+ k)) (if (<= k n) (setq r (cons 1 r)) (setq r (cons 0 r)) ) ) (setq l (cons (reverse r) l) r nil) ) (reverse l) ) (prompt "\nSelect overlapping group of blocks...") (setq s (ssget "_:L" '((0 . "INSERT")))) (if s (progn (setq i (sslength s)) (setq m (dispositionmatrix i)) (repeat i (setq l (cons (list (acet-ent-geomextents (setq b (ssname s (setq i (1- i))))) b) l)) ) (setq c (mapcar (function (lambda ( x ) (/ x (length l)))) (apply (function mapcar) (cons (function +) (mapcar (function (lambda ( x y ) (mapcar (function (lambda ( a b ) (/ (+ a b) 2))) x y))) (mapcar (function caar) l) (mapcar (function cadar) l)))))) (setq k 0) (foreach r m (foreach v r (if (= v 1) (setq rn (cons (nth k l) rn) k (1+ k)) (setq rn (cons nil rn)) ) ) (setq mn (cons (reverse rn) mn) rn nil) ) (setq mn (reverse mn)) (setq w (apply (function max) (mapcar (function (lambda ( x ) (apply (function +) (mapcar (function (lambda ( y ) (if y (abs (- (car (cadr (car y))) (car (car (car y))))) 0.0))) x)))) mn))) (setq h (apply (function max) (mapcar (function (lambda ( x ) (apply (function +) (mapcar (function (lambda ( y ) (if y (abs (- (cadr (cadr (car y))) (cadr (car (car y))))) 0.0))) x)))) (apply (function mapcar) (cons (function list) mn))))) (setq bp (mapcar (function -) c (list (/ w 2) (/ h 2)))) (setq rh 0.0) (foreach rn mn (setq bp (mapcar (function +) bp (list 0.0 rh))) (setq rh 0.0) (foreach vn rn (if vn (progn (vla-move (vlax-ename->vla-object (cadr vn)) (vlax-3d-point (caar vn)) (vlax-3d-point bp)) (setq bp (mapcar (function +) bp (list (abs (- (car (cadr (car vn))) (car (car (car vn))))) 0.0))) ) ) (if (and vn (< rh (abs (- (cadr (cadr (car vn))) (cadr (car (car vn))))))) (setq rh (abs (- (cadr (cadr (car vn))) (cadr (car (car vn)))))) ) ) (setq bp (subst (- (car c) (/ w 2)) (car bp) bp)) ) ) ) (princ) )
Message 6 of 11
Hello Brother, What is command for your lisp program when I loaded in autocad?
Message 7 of 11
Kent1Cooper
@Anonymous wrote:
.... What is command for your lisp program when I loaded in autocad?
Whenever a command is defined with this kind of starting line:
   (defun c:scatterblks ....
the command name is always the part immediately after the c:, in this case, SCATTERBLKS [not case-sensitive].
Kent Cooper, AIA
Message 8 of 11
Thanks for this great solution! How would someone update the script to add some predefined space between blocks? (Both vertically and horizontally)
Message 9 of 11
marko_ribar
Here you go...
(defun c:scatterblks-with-gaps ( / dispositionmatrix s g i m l b c k rn mn w h bp rh )
  (vl-load-com)
    (setq k 0)
    (repeat f
      (repeat f
        (setq k (1+ k))
        (if (<= k n)
          (setq r (cons 1 r))
          (setq r (cons 0 r))
    (reverse l)
  (initget 4)
  (setq g (getdist "\nPick or specify gap distance <0.0> : "))
  (if (null g)
    (setq g 0.0)
  (if s
    (progn
      (repeat i
      (setq k 0)
      (foreach r m
        (foreach v r
          (if (= v 1)
      (setq bp (mapcar (function -) c (list (+ (/ w 2) (/ (* (1- (length (car m))) g) 2)) (+ (/ h 2) (/ (* (1- (length m)) g) 2)))))
      (setq rh 0.0)
      (foreach rn mn
        (setq rh 0.0)
        (foreach vn rn
          (if vn
            (progn
              (setq bp (mapcar (function +) bp (list (+ g (abs (- (car (cadr (car vn))) (car (car (car vn)))))) 0.0)))
          (if (and vn (< rh (+ g (abs (- (cadr (cadr (car vn))) (cadr (car (car vn))))))))
            (setq rh (+ g (abs (- (cadr (cadr (car vn))) (cadr (car (car vn)))))))
        (setq bp (subst (- (car c) (+ (/ w 2) (/ (* (1- (length (car m))) g) 2))) (car bp) bp))
  (princ)
HTH. M.R.
Message 10 of 11
Amazing! Thank you so much for the prompt reply!
It works like a charm!
Message 11 of 11
pukkalapoom
AutoCAD Inside the Factory
