Alias for "Laymch" name option
Intuos5
Advisor Advisor
Message 1 of 11
Intuos5
Is it possible to assign "CL" to the command Laymch with the option name as default? This is the way I set things up in Rhino and would like for the UI pop-up to be called each time I use the command.
Replies (10)
Message 2 of 11
ВeekeeCZ
Express Tools / Tools / Command Aliases / Add...
Message 3 of 11
Intuos5
Then where do I specify the "N" [name] + "Enter"? I would like those to be part of the macro/ alias.
Message 4 of 11
ВeekeeCZ
That's not possible with aliases.
For this, you can either have a tool on Toolpalette (simple, but run by a mouse click) or a keyboard shortcut (eg ctrl+alt+m).
Or a LISP. Ony this gives you the ability to create a command name (similarly as an alias)
Message 5 of 11
Intuos5
So in that case, I would need to create an LISP and assign an alias to that. Though I am not familiar with LISP or programming in general, so I am hoping someone could lend me a hand.
Message 6 of 11
ВeekeeCZ
So you want to just select objects, type a command, pick a target layer from a list?
Message 7 of 11
Intuos5
Yes, that's the desired workflow.
And I like that this dialog allows you to type in the layer, so by naming the layers with a number prefix, I type the number and hit enter.
Message 8 of 11
ВeekeeCZ
Use some of THESE methods to load a lisp...
(defun c:LaymchD ( / s)
  (if (setq s (ssget "_:L"))
    (progn
      (initcommandversion)
      (command "_.laymch" s "" "_n")))
  (princ)
Message 9 of 11
Intuos5
Thank you very much.
I may be missing something though, I changed the LISP name to ChangeToLayer, like so:
(defun c:ChangeToLayer ( / s)
    (progn
  (princ)
 Ran it through appload for the .lsp file, closed and opened autocad, reinitiated the .pgp, but it still won't find the command in _aliasedit. Sorry for such a basic question, but I cannot find an answer through searching... 😅
Message 10 of 11
ВeekeeCZ
It probably won't be there.
I think that you can simply type in the command name manually as it's not listed in the dropdown.
Anyway, you can also do this manually - as I always do. Click on the big "A" menu, type PGP, pick "Edit pgp.." and add your new alias to the very end of the file. Syntax is:
alias, *command name
better leave the last line empty.
Also, use the Start-up suitcase in the appload command to have your LSIP command always loaded.
Message 11 of 11
Intuos5
Perfect, got it. Thank you very much, I'll be using this extensively 😄
