AddSurfaceDrawingObjects lisp
I am trying to fins a way to use the "AddSurfaceDrawingObjects" command without the dialogue box.
I want to choose "Blocks" in the object type in the dialogue box from the command line and populate the description with the date, time, and user name.
Then I want to select the previous selection and enter.
See the lisp below:
I'm sure there is probably a more elegant way of doing this:
(defun C:XS ()
(c:xe)
(c:xle)
(Command "AddSurfaceDrawingObjects" pause "p")
(defun C:XLE (/
entSelection
intCount
objAttribute
objSelection
ssSelections
strTextstring
(if (setq ssSelections (ssget (list (cons 2 "XLABEL"))))
(repeat (setq intCount (sslength ssSelections))
(setq intCount (1- intCount)
entSelection (ssname ssSelections intCount)
objSelection (vlax-ename->vla-object entSelection)
(foreach objAttribute (vlax-invoke objSelection "getattributes")
(if (= (vla-get-tagstring objAttribute) "ELEV1")
(if (/= (setq strTextstring (vla-get-textstring objAttribute)) "")
(progn
(setq lstInsertion (vlax-get objSelection "insertionpoint")
lstInsertion (list (car lstInsertion)
(cadr lstInsertion)
(atof strTextString)
(vlax-put objSelection "insertionpoint" lstInsertion)
(princ)
(vl-load-com)
(defun c:xe ( / blockname sset); filter all blocks of same name with one click
(setq blockname (cdr (assoc 2 (entget (car (entsel))))))
(setq sset (ssget "x" (list (cons 2 blockname))))
(sssetfirst sset sset)
(princ (strcat "\nSelected " (itoa (sslength sset)) " instances of block \"" blockname "\"."))
(princ)
DannyNL
Not sure what AutoCAD vertical you are using (AutoCAD Vanilla doesn't have the AddSurfaceDrawingObjects command), but usually you can suppress dialogue boxes by prefixing the command with a minus sign (so the command -AddSurfaceDrawingObjects) or by setting the CMDDIA variable to 0.
I am using Civil 3D 2017. -AddSurfaceDrawingObjects does not work. I tried the CMDDIA variable, but the dialogue box still pops up to select the drawing object type.
DannyNL
Mmmh...that's too bad.
As I do not have Civil 3D I'm not able to further check on this and find a solution, so hopefully someone else can help you out.
