Adding unique ID to Blocks and then color it
vyshakhgnair_cvr
vyshakhgnair_cvr
How to add a unique id to each block in a model in Autocad so that it can retrieve using Autodesk api to color specific blocks?
paullimapa
AutoCAD Blocks support Attributes which can have a unique value.
Perhaps you can try exploring this option?
Paul Li
IT Specialist
@The Office
vyshakhgnair_cvr
Yeah, I have tried to implement that but I could implement that only in the formats such as dwg, dwf. And couldn't find any API documentation which tries to extract value embedded in a file.
paullimapa
I though you were only addressing dwg files then the following may be of interest to you:
https://forums.autodesk.com/t5/net/reg-extract-attributes-without-opening-drawing-file/td-p/5455950
Here's a method using ObjectARX:
https://adndevblog.typepad.com/autocad/2012/12/get-the-attribute-values-from-block-references-insert...
Then there are products that can extract attributes without AutoCAD:
https://www.autodwg.com/AttributeExtraction/
Paul Li
IT Specialist
@The Office
vyshakhgnair_cvr
Thank you I'll go through these.
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
