adding modifiers to a command?
Shay.Gaghe
Shay.Gaghe
hi all
I’ve created a lisp-based command that have some options included.
I would like to add modifiers (Shift,CTL,Alt) to my click and have them trigger corresponding command options.
For example, if my command is “test [A,B,C]”, by invoking “test” ,the command is asking to select object, when I select the objects with CTL , the command will use option A, when using ALT with clicking, the command use option B and so on.
Is there a CUIx way to do it? Or do I have to code it in the lisp?
Shay
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
Moshe-A
@Shay.Gaghe  hi,
you can trigger your lisp command from CUI interface
Keyboard shortcut\Shortcut keys
as far as know it respond to ctrl and\or shift (not alt)
moshe
