Adding Lenght to area Label cell
Dear friends ;
I'm using @Anonymous-lee's Area Label v1-9 .It's working great for creating cells with closed p.lines and extracting them to excell , flawless.I i need the length of this p.lines and layer names then extract them in a single cell.I will upload screenshots and a dwg example for make things easier . is it possible to make a cell like this ?
Thanks A lot
Sea-Haven
The 1st step is save Area label V1-9 to a new file name. 2nd is to add to the code length, the layer would require a different approach as what happens if crossing  objects are on two different layers ? Adding a Layiso would be the simplest.
Lastly why not ask the author Lee for a modification after all its his code your using. He is pretty generous with his time.
I'm pretty new on this lisp and modification things and also i tried to contact him on his website but i didn't get a reply . .(
CADaSchtroumpf
I have quickly adjust the code only for table, not for file.
Test it...
;;---------------------=={ Area Label }==---------------------;;
;;  Allows the user to label picked areas or objects and      ;;
;;  either display the area in an ACAD Table (if available),  ;;
;;  optionally using fields to link area numbers and objects; ;;
;;  or write it to file.                                      ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version 1.9    -    29-10-2011                            ;;
(defun c:AT nil (AreaLabel   t))  ;; Areas to Table
(defun c:AF nil (AreaLabel nil))  ;; Areas to File
(defun AreaLabel ( flag / *error* _startundo _endundo _centroid _text _open _select _getobjectid _isannotative
                          acdoc acspc ap ar as cf cm el fd fl fo n of om p1 pf pt sf st t0 t1 t2 t3 tb th ts tx ucsxang ucszdir )
  ;;                         Adjustments                        ;;
  (setq h1 "Area Table"  ;; Heading
        t0 "Layer"       ;; Layer
        t1 "Number"      ;; Number Title
        t2 "Area"        ;; Area Title
        t3 "Length"      ;; Length Title
        pf ""            ;; Number Prefix (optional, "" if none)
        sf ""            ;; Number Suffix (optional, "" if none)
        ap ""            ;; Area Prefix (optional, "" if none)
        as ""            ;; Area Suffix (optional, "" if none)
        cf 1.0           ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2)
        fd t             ;; Use fields to link numbers/objects to table (t=yes, nil=no)
        fo "%lu6%qf1"    ;; Area field formatting
  (defun *error* ( msg )
    (if cm (setvar 'CMDECHO cm))
    (if el (progn (entdel el) (setq el nil)))
    (if acdoc (_EndUndo acdoc))
    (if (and of (eq 'FILE (type of))) (close of))
    (if (and Shell (not (vlax-object-released-p Shell))) (vlax-release-object Shell))
    (if (null (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
        (princ (strcat "\n--> Error: " msg))
    (princ)
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (defun _centroid ( space objs / reg cen )
    (setq reg (car (vlax-invoke space 'addregion objs))
          cen (vlax-get reg 'centroid)
    (vla-delete reg) (trans cen 1 0)
  (defun _text ( space point string height rotation / text )
    (setq text (vla-addtext space string (vlax-3D-point point) height))
    (vla-put-alignment text acalignmentmiddlecenter)
    (vla-put-textalignmentpoint text (vlax-3D-point point))
    (vla-put-rotation text rotation)
    text
  (defun _Open ( target / Shell result )
    (if (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
      (progn
        (setq result
          (and (or (eq 'INT (type target)) (setq target (findfile target)))
            (not
              (vl-catch-all-error-p
                (vl-catch-all-apply 'vlax-invoke (list Shell 'Open target))
    result
  (defun _Select ( msg pred func init / e ) (setq pred (eval pred))
    (while
      (progn (setvar 'ERRNO 0) (apply 'initget init) (setq e (func msg))
        (cond
          ( (= 7 (getvar 'ERRNO))
            (princ "\nMissed, try again.")
          ( (eq 'STR (type e))
            nil
          ( (vl-consp e)
            (if (and pred (not (pred (setq e (car e)))))
              (princ "\nInvalid Object Selected.")
    e
  (defun _GetObjectID ( doc obj )
    (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
      (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
      (itoa (vla-get-Objectid obj))
  (defun _isAnnotative ( style / object annotx )
    (and
      (setq object (tblobjname "STYLE" style))
      (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
      (= 1 (cdr (assoc 1070 (reverse annotx))))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
        ucszdir (trans '(0. 0. 1.) 1 0 t)
        ucsxang (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 ucszdir))
  (_StartUndo acdoc)
  (setq cm (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (setq om (eq "1" (cond ((getenv "LMAC_AreaLabel")) ((setenv "LMAC_AreaLabel" "0")))))
  (setq ts
    (/ (getvar 'TEXTSIZE)
      (if (_isAnnotative (getvar 'TEXTSTYLE))
        (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0
  (cond
    ( (not (vlax-method-applicable-p acspc 'addtable))
      (princ "\n--> Table Objects not Available in this Version.")
    ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
      (princ "\n--> Current Layer Locked.")
    ( (not
        (setq *al:num
          (cond
              (getint
                (strcat "\nSpecify Starting Number <"
                  (itoa (setq *al:num (1+ (cond ( *al:num ) ( 0 ))))) ">: "
            ( *al:num )
    ( flag
      (setq th
        (* 2.
          (if
            (zerop
              (setq th
                (vla-gettextheight
                  (setq st
                    (vla-item
                      (vla-item
                        (vla-get-dictionaries acdoc) "ACAD_TABLESTYLE"
                      (getvar 'CTABLESTYLE)
                  acdatarow
            ts
            (/ th
              (if (_isAnnotative (vla-gettextstyle st acdatarow))
      (if
        (cond
            (progn (initget "Add")
              (vl-consp (setq pt (getpoint "\nPick Point for Table <Add to Existing>: ")))
            (setq tb
              (vla-addtable acspc
                (vlax-3D-point (trans pt 1 0)) 2 4 th (* 0.8 th (max (strlen t1) (strlen t2)))
            (vla-put-direction tb (vlax-3D-point (getvar 'UCSXDIR)))
            (vla-settext tb 0 0 h1)
            (vla-settext tb 1 0 t0)
            (vla-settext tb 1 1 t1)
            (vla-settext tb 1 2 t2)
            (vla-settext tb 1 3 t3)
            (while
              (progn
                (if om
                  (setq p1
                    (_Select (strcat "\nSelect Object [Pick] <Exit>: ")
                     '(lambda ( x )
                        (and
                          (vlax-property-available-p (vlax-ename->vla-object x) 'area)
                          (not (eq "HATCH" (cdr (assoc 0 (entget x)))))
                          (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x))
                      entsel '("Pick")
                  (progn (initget "Object") (setq p1 (getpoint "\nPick Area [Object] <Exit>: ")))
                (cond
                  ( (null p1)
                    (vla-delete tb)
                  ( (eq "Pick" p1)
                    (setq om nil) t
                  ( (eq "Object" p1)
                    (setq om t)
                  ( (eq 'ENAME (type p1))
                    (setq tx
                      (cons
                        (_text acspc
                          (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1))))
                          (strcat pf (itoa *al:num) sf)
                          ts
                          ucsxang
                        tx
                    (vla-insertrows tb (setq n 2) th 1)
                    (vla-settext tb n 3
                      (if fd
                        (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                          (_GetObjectID acdoc p1) ">%).Length \\f \"" fo "\">%"
                        (strcat ap (rtos (* cf (vla-get-length p1)) 2) as)
                    (vla-settext tb n 2
                      (if fd
                          (_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%"
                        (strcat ap (rtos (* cf (vla-get-area p1)) 2) as)
                    (vla-settext tb n 1
                      (if fd
                          (_GetObjectID acdoc (car tx)) ">%).TextString>%"
                    (vla-settext tb n 0
                      (if fd
                          (_GetObjectID acdoc (car tx)) ">%).Layer>%"
                        (vla-get-layer p1)
                    nil
                  ( (vl-consp p1)
                    (setq el (entlast))
                    (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "")
                    (if (not (equal el (setq el (entlast))))
                      (progn
                        (setq tx
                          (cons
                            (_text acspc
                              (_centroid acspc (list (vlax-ename->vla-object el)))
                              ts
                              ucsxang
                            tx
                        (vla-settext tb n 3 (strcat ap (rtos (* cf (vlax-curve-getdistatparam el (vlax-curve-getendparam el))) 2) as))
                        (vla-settext tb n 2 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as))
                        (vla-settext tb n 1
                          (if fd
                        (vla-settext tb n 0 (vla-get-layer (vlax-ename->vla-object el)))
                        (redraw el 3)
                        nil
                      (vla-delete tb)
            (not (vlax-erased-p tb))
            (and
              (setq tb
                (_Select "\nSelect Table to Add to: "
                 '(lambda ( x ) (eq "ACAD_TABLE" (cdr (assoc 0 (entget x))))) entsel nil
              (< 1 (vla-get-columns (setq tb (vlax-ename->vla-object tb))))
            (setq n (1- (vla-get-rows tb)) *al:num (1- *al:num))
        (progn
          (while
            (if om
              (setq p1
                (_Select (strcat "\nSelect Object [" (if tx "Undo/" "") "Pick] <Exit>: ")
                 '(lambda ( x )
                    (and
                  entsel (list (if tx "Undo Pick" "Pick"))
              (progn (initget (if tx "Undo Object" "Object"))
                (setq p1 (getpoint (strcat "\nPick Area [" (if tx "Undo/" "") "Object] <Exit>: ")))
            (cond
              ( (and tx (eq "Undo" p1))
                (vla-deleterows tb n 1)
                (vla-delete (car tx))
                (setq n (1- n) tx (cdr tx) *al:num (1- *al:num))
              ( (eq "Undo" p1)
                (princ "\n--> Nothing to Undo.")
              ( (eq "Object" p1)
                (setq om t)
              ( (eq "Pick" p1)
                (setq om nil)
              ( (and om (eq 'ENAME (type p1)))
                (setq tx
                  (cons
                    (_text acspc
                      (strcat pf (itoa (setq *al:num (1+ *al:num))) sf)
                      ts
                      ucsxang
                    tx
                (vla-insertrows tb (setq n (1+ n)) th 1)
                    (vla-settext tb n 3
                      (if fd
                    (vla-settext tb n 2
                      (if fd
                    (vla-settext tb n 1
                      (if fd
                    (vla-settext tb n 0
                      (if fd
                        (vla-get-layer p1)
              ( (vl-consp p1)
                (setq el (entlast))
                  (progn
                    (setq tx
                      (cons
                        (_text acspc
                          ts
                          ucsxang
                        tx
                    (vla-settext tb n 1
                      (if fd
                    (redraw el 3)
                  (princ "\n--> Error Retrieving Area.")
      (and
        (setq fl (getfiled "Create Output File" (cond ( *file* ) ( "" )) "txt;csv;xls" 1))
        (setq of (open fl "w"))
      (setq *file*  (vl-filename-directory fl)
            de      (cdr (assoc (strcase (vl-filename-extension fl) t) '((".txt" . "\t") (".csv" . ",") (".xls" . "\t"))))
      (write-line h1 of)
      (write-line (strcat t0 t1 de t2 t3) of)
      (while
        (if om
          (setq p1
             '(lambda ( x )
                (and
              entsel '("Pick")
          (progn (initget "Object") (setq p1 (getpoint (strcat "\nPick Area [Object] <Exit>: "))))
        (cond
          ( (eq "Object" p1)
            (setq om t)
          ( (eq "Pick" p1)
            (setq om nil)
            (_text acspc
              ts
              ucsxang
            (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vla-get-area p1)) 2) as) of)
          ( (vl-consp p1)
            (setq el (entlast))
              (progn
                (_text acspc
                  ts
                  ucsxang
                (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vlax-curve-getarea el)) 2) as) of)
                (redraw el 3)
      (setq of (close of))
      (_Open (findfile fl))
  (setenv "LMAC_AreaLabel" (if om "1" "0"))
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
(princ "\n:: AreaLabel.lsp | Version 1.9 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Commands: \"AT\" for ACAD Table, \"AF\" for File ::")
(princ)
;;                         End of File                        ;;
Sea-Haven
Its always a good idea to aknowledge changes to some one else code maybe add your name to
  ;;                         Adjustments                        ;;
 ;;               length added by  CadaStroumph Nov 2019        ;;
Hi friend ;
It's working perfect just perfect . Thank you very much it helps a lot and saving tons of time )
CADaSchtroumpf
Be careful with the layer information, because if the 'Pick Area' option is used the returned layer will always be the current layer.
This is unavoidable and is due to the use of the command 'BOUNDARY' in the code. The 'Object' option will provide the right information.
I completed the code to have the same for file output and added the notification of modification in the header by me as suggested by sea.haven.
My apologies to LeeMac.
