I have quickly adjust the code only for table, not for file.
Test it...
;;---------------------=={ Area Label }==---------------------;;
;; Allows the user to label picked areas or objects and ;;
;; either display the area in an ACAD Table (if available), ;;
;; optionally using fields to link area numbers and objects; ;;
;; or write it to file. ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; Version 1.9 - 29-10-2011 ;;
(defun c:AT nil (AreaLabel t)) ;; Areas to Table
(defun c:AF nil (AreaLabel nil)) ;; Areas to File
(defun AreaLabel ( flag / *error* _startundo _endundo _centroid _text _open _select _getobjectid _isannotative
acdoc acspc ap ar as cf cm el fd fl fo n of om p1 pf pt sf st t0 t1 t2 t3 tb th ts tx ucsxang ucszdir )
;; Adjustments ;;
(setq h1 "Area Table" ;; Heading
t0 "Layer" ;; Layer
t1 "Number" ;; Number Title
t2 "Area" ;; Area Title
t3 "Length" ;; Length Title
pf "" ;; Number Prefix (optional, "" if none)
sf "" ;; Number Suffix (optional, "" if none)
ap "" ;; Area Prefix (optional, "" if none)
as "" ;; Area Suffix (optional, "" if none)
cf 1.0 ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2)
fd t ;; Use fields to link numbers/objects to table (t=yes, nil=no)
fo "%lu6%qf1" ;; Area field formatting
(defun *error* ( msg )
(if cm (setvar 'CMDECHO cm))
(if el (progn (entdel el) (setq el nil)))
(if acdoc (_EndUndo acdoc))
(if (and of (eq 'FILE (type of))) (close of))
(if (and Shell (not (vlax-object-released-p Shell))) (vlax-release-object Shell))
(if (null (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
(princ (strcat "\n--> Error: " msg))
(princ)
(defun _StartUndo ( doc ) (_EndUndo doc)
(vla-StartUndoMark doc)
(defun _EndUndo ( doc )
(if (= 8 (logand 8 (getvar 'UNDOCTL)))
(vla-EndUndoMark doc)
(defun _centroid ( space objs / reg cen )
(setq reg (car (vlax-invoke space 'addregion objs))
cen (vlax-get reg 'centroid)
(vla-delete reg) (trans cen 1 0)
(defun _text ( space point string height rotation / text )
(setq text (vla-addtext space string (vlax-3D-point point) height))
(vla-put-alignment text acalignmentmiddlecenter)
(vla-put-textalignmentpoint text (vlax-3D-point point))
(vla-put-rotation text rotation)
text
(defun _Open ( target / Shell result )
(if (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
(progn
(setq result
(and (or (eq 'INT (type target)) (setq target (findfile target)))
(not
(vl-catch-all-error-p
(vl-catch-all-apply 'vlax-invoke (list Shell 'Open target))
result
(defun _Select ( msg pred func init / e ) (setq pred (eval pred))
(while
(progn (setvar 'ERRNO 0) (apply 'initget init) (setq e (func msg))
(cond
( (= 7 (getvar 'ERRNO))
(princ "\nMissed, try again.")
( (eq 'STR (type e))
nil
( (vl-consp e)
(if (and pred (not (pred (setq e (car e)))))
(princ "\nInvalid Object Selected.")
e
(defun _GetObjectID ( doc obj )
(if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
(vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
(itoa (vla-get-Objectid obj))
(defun _isAnnotative ( style / object annotx )
(and
(setq object (tblobjname "STYLE" style))
(setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
(= 1 (cdr (assoc 1070 (reverse annotx))))
(setq acdoc (vla-get-activedocument (vlax-get-acad-object))
acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
ucszdir (trans '(0. 0. 1.) 1 0 t)
ucsxang (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 ucszdir))
(_StartUndo acdoc)
(setq cm (getvar 'CMDECHO))
(setvar 'CMDECHO 0)
(setq om (eq "1" (cond ((getenv "LMAC_AreaLabel")) ((setenv "LMAC_AreaLabel" "0")))))
(setq ts
(/ (getvar 'TEXTSIZE)
(if (_isAnnotative (getvar 'TEXTSTYLE))
(cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0
(cond
( (not (vlax-method-applicable-p acspc 'addtable))
(princ "\n--> Table Objects not Available in this Version.")
( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
(princ "\n--> Current Layer Locked.")
( (not
(setq *al:num
(cond
(getint
(strcat "\nSpecify Starting Number <"
(itoa (setq *al:num (1+ (cond ( *al:num ) ( 0 ))))) ">: "
( *al:num )
( flag
(setq th
(* 2.
(if
(zerop
(setq th
(vla-gettextheight
(setq st
(vla-item
(vla-item
(vla-get-dictionaries acdoc) "ACAD_TABLESTYLE"
(getvar 'CTABLESTYLE)
acdatarow
ts
(/ th
(if (_isAnnotative (vla-gettextstyle st acdatarow))
(if
(cond
(progn (initget "Add")
(vl-consp (setq pt (getpoint "\nPick Point for Table <Add to Existing>: ")))
(setq tb
(vla-addtable acspc
(vlax-3D-point (trans pt 1 0)) 2 4 th (* 0.8 th (max (strlen t1) (strlen t2)))
(vla-put-direction tb (vlax-3D-point (getvar 'UCSXDIR)))
(vla-settext tb 0 0 h1)
(vla-settext tb 1 0 t0)
(vla-settext tb 1 1 t1)
(vla-settext tb 1 2 t2)
(vla-settext tb 1 3 t3)
(while
(progn
(if om
(setq p1
(_Select (strcat "\nSelect Object [Pick] <Exit>: ")
'(lambda ( x )
(and
(vlax-property-available-p (vlax-ename->vla-object x) 'area)
(not (eq "HATCH" (cdr (assoc 0 (entget x)))))
(or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x))
entsel '("Pick")
(progn (initget "Object") (setq p1 (getpoint "\nPick Area [Object] <Exit>: ")))
(cond
( (null p1)
(vla-delete tb)
( (eq "Pick" p1)
(setq om nil) t
( (eq "Object" p1)
(setq om t)
( (eq 'ENAME (type p1))
(setq tx
(cons
(_text acspc
(_centroid acspc (list (setq p1 (vlax-ename->vla-object p1))))
(strcat pf (itoa *al:num) sf)
ts
ucsxang
tx
(vla-insertrows tb (setq n 2) th 1)
(vla-settext tb n 3
(if fd
(strcat "%<\\AcObjProp Object(%<\\_ObjId "
(_GetObjectID acdoc p1) ">%).Length \\f \"" fo "\">%"
(strcat ap (rtos (* cf (vla-get-length p1)) 2) as)
(vla-settext tb n 2
(if fd
(_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%"
(strcat ap (rtos (* cf (vla-get-area p1)) 2) as)
(vla-settext tb n 1
(if fd
(_GetObjectID acdoc (car tx)) ">%).TextString>%"
(vla-settext tb n 0
(if fd
(_GetObjectID acdoc (car tx)) ">%).Layer>%"
(vla-get-layer p1)
nil
( (vl-consp p1)
(setq el (entlast))
(vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "")
(if (not (equal el (setq el (entlast))))
(progn
(setq tx
(cons
(_text acspc
(_centroid acspc (list (vlax-ename->vla-object el)))
ts
ucsxang
tx
(vla-settext tb n 3 (strcat ap (rtos (* cf (vlax-curve-getdistatparam el (vlax-curve-getendparam el))) 2) as))
(vla-settext tb n 2 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as))
(vla-settext tb n 1
(if fd
(vla-settext tb n 0 (vla-get-layer (vlax-ename->vla-object el)))
(redraw el 3)
nil
(vla-delete tb)
(not (vlax-erased-p tb))
(and
(setq tb
(_Select "\nSelect Table to Add to: "
'(lambda ( x ) (eq "ACAD_TABLE" (cdr (assoc 0 (entget x))))) entsel nil
(< 1 (vla-get-columns (setq tb (vlax-ename->vla-object tb))))
(setq n (1- (vla-get-rows tb)) *al:num (1- *al:num))
(progn
(while
(if om
(setq p1
(_Select (strcat "\nSelect Object [" (if tx "Undo/" "") "Pick] <Exit>: ")
'(lambda ( x )
(and
entsel (list (if tx "Undo Pick" "Pick"))
(progn (initget (if tx "Undo Object" "Object"))
(setq p1 (getpoint (strcat "\nPick Area [" (if tx "Undo/" "") "Object] <Exit>: ")))
(cond
( (and tx (eq "Undo" p1))
(vla-deleterows tb n 1)
(vla-delete (car tx))
(setq n (1- n) tx (cdr tx) *al:num (1- *al:num))
( (eq "Undo" p1)
(princ "\n--> Nothing to Undo.")
( (eq "Object" p1)
(setq om t)
( (eq "Pick" p1)
(setq om nil)
( (and om (eq 'ENAME (type p1)))
(setq tx
(cons
(_text acspc
(strcat pf (itoa (setq *al:num (1+ *al:num))) sf)
ts
ucsxang
tx
(vla-insertrows tb (setq n (1+ n)) th 1)
(vla-settext tb n 3
(if fd
(vla-settext tb n 2
(if fd
(vla-settext tb n 1
(if fd
(vla-settext tb n 0
(if fd
(vla-get-layer p1)
( (vl-consp p1)
(setq el (entlast))
(progn
(setq tx
(cons
(_text acspc
ts
ucsxang
tx
(vla-settext tb n 1
(if fd
(redraw el 3)
(princ "\n--> Error Retrieving Area.")
(and
(setq fl (getfiled "Create Output File" (cond ( *file* ) ( "" )) "txt;csv;xls" 1))
(setq of (open fl "w"))
(setq *file* (vl-filename-directory fl)
de (cdr (assoc (strcase (vl-filename-extension fl) t) '((".txt" . "\t") (".csv" . ",") (".xls" . "\t"))))
(write-line h1 of)
(write-line (strcat t0 t1 de t2 t3) of)
(while
(if om
(setq p1
'(lambda ( x )
(and
entsel '("Pick")
(progn (initget "Object") (setq p1 (getpoint (strcat "\nPick Area [Object] <Exit>: "))))
(cond
( (eq "Object" p1)
(setq om t)
( (eq "Pick" p1)
(setq om nil)
(_text acspc
ts
ucsxang
(write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vla-get-area p1)) 2) as) of)
( (vl-consp p1)
(setq el (entlast))
(progn
(_text acspc
ts
ucsxang
(write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vlax-curve-getarea el)) 2) as) of)
(redraw el 3)
(setq of (close of))
(_Open (findfile fl))
(setenv "LMAC_AreaLabel" (if om "1" "0"))
(_EndUndo acdoc)
(princ)
(vl-load-com)
(princ)
(princ "\n:: AreaLabel.lsp | Version 1.9 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Commands: \"AT\" for ACAD Table, \"AF\" for File ::")
(princ)
;; End of File ;;
