add to lists inside list
DGRL
Advisor Advisor
Message 1 of 22
DGRL
Dear forum members
I am looking for a way to add "X" to all lists inside a list
This is the list
(("ISO_PIPESPEC" "n.v.t.1" "Prompt 1") ("ISO_MEDIUM" "n.v.t.2" "Prompt 2") ("ISO_DESIGN_PRESS" "n.v.t.3" "Prompt 3"))
And I want to get it like this
(("ISO_PIPESPEC" "n.v.t.1" "Prompt 1" "X") ("ISO_MEDIUM" "n.v.t.2" "Prompt 2" "X") ("ISO_DESIGN_PRESS" "n.v.t.3" "Prompt 3" "X"))
Below is what I tried and didn't work out
Trying it like this
(foreach x vier (setq a (append a (car vier) '("X")))) will make 1 long list and I need multiple lists inside a list
trying this
(foreach x (car vier) (setq a (append a vier '("")))) will make the list how I want it only it placed the "X" 1 time as last list
Trying this
(foreach x vier (setq a (append a x '("")))) will make 1 long list and I need multiple lists inside a list
Trying this will add the value to each member of the lists
(mapcar '(lambda ( x ) (strcat "insert text here" x)) 'vier)
vier is the var name I used that contains the list
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Accepted solutions (4)
Replies (21)
Message 21 of 22
Ranjit_Singh
Let's say lst was the master list. Since "X" is conveniently placed at the end of every list you could reverse, cdr and reverse again.
-DELETED-
However, if "X" was not the last element (or maybe it was missing from a few of the lists), like this
-DELETED
then below may work
-DELETED-
 EDIT: May apologies. I wasn't reading the whole thread and @Kent1Cooper's reply came as I was typing, else I would had understood your intent. Deleting the code so you can give it a try.
Message 22 of 22
DGRL
Hi @Ranjit_Singh @Kent1Cooper @ВeekeeCZ @_gile @ActivistInvestor
Thanks to you all for helping me out and most of all for helping me to learn to code lisp
I finished the routine i was working on just a minute ago and it is working perfect.
Kind Regards
