Reactor when switch between open drawings
C.Utzinger
Message 1 of 12
C.Utzinger
HI
Is there some kind of Reactor when you are switching between open drawings?
I have some Information displayed in MODEMACRO, and I need to execute a routine or load a .lsp when I switch the drawing.
Please help...
Regards
Replies (11)
Message 2 of 12
ВeekeeCZ
See help HERE
Message 3 of 12
_gile
Have a look at vlr-docmanager-reactor.
@ВeekeeCZ is still faster than me today.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 12
C.Utzinger
OK!
I'm a littlebit lost with Callback Functions. The following does not work...
(defun c:<Test1 ( / )
(defun RTF (calling-reactor commandInfo / dwgname filesize)
  (vl-load-com)
  (setq dwgname (cadr commandInfo)
    filesize (vl-file-size dwgname)
  (alert (strcat "The file size of " dwgname " is "
      (itoa filesize) " bytes."
 (princ)
(setq VTFRXNF (vlr-docmanager-reactor nil '((:vlr-documentBecameCurrent   . RTF))))
Kind regards
Message 5 of 12
ActivistInvestor
The documentBecameCurrent notification is going to fire 3 times every time you switch documents (no, I don't know why).
You really don't want to do that, but if you insist, the only argument is the AcadDocument com wrapper for the document that's being made current:
(vl-load-com)
(vl-load-reactors)
(defun C:TEST()
       '((:VLR-documentBecameCurrent . callback)
(defun callback (reactor args / fname)
     (setq fname (vla-get-fullname (car args)))
     (if (/= fname "")
         (vla-SetVariable (car args) "MODEMACRO"
             (strcat fname "  " (rtos (vl-file-size fname) 2 0))
Message 6 of 12
C.Utzinger
Thank you, but what is so terrible about this?
      '((:VLR-documentBecameCurrent . callback)))
  (defun callback (reactor args / fname info)
          (setq info (getvar 'MODEMACRO)
                info (if (= (substr info 1 3) "SPI")
                         (vl-string-left-trim " /SPI-:1234567890CMBaselZürichBern" info)
                         info)
                info (vl-string-left-trim " '" info)
                info (if (= info "")
                     (strcat "SPI " *standort* " - 1:" (itoa *mstb*) " / " *einht*)
                     (strcat "SPI " *standort* " - 1:" (itoa *mstb*) " / " *einht* "  '  " info))
          (vla-SetVariable (car args) "MODEMACRO" info)
Best regards
Message 7 of 12
ActivistInvestor
                         info)
Best regards
What's so terrible about it?  Nothing directly, but did you check to see how many times the callback is fired every time you switch documets?
I just don't savor the idea that a callback is being fired 3 times when it should only fire once.
Message 8 of 12
Ranjit_Singh
Maybe OP should watch for :vlr-documentToBeActivated event.
Message 9 of 12
ActivistInvestor
Yes he can, because in spite of its name, it actually fires after the document has already been activated.
Message 10 of 12
C.Utzinger
Good Morning
Thank you a lot for the answers.
I will use :vlr-documentToBeActivated, it makes what i was looking for.
Kind regards.
How can I include the text from an other comment in my reply, like ActivistInverstor
did in his last comment?
Message 11 of 12
Ranjit_Singh
When replying, look for the QUOTE button and click that.
Message 12 of 12
C.Utzinger
Ahhhh, thank you
