Add section beam?
Add section beam?
Add section beam?
Hi all,
Can someone have code or solution to add beam rectang to section ? (see file attached)
Please tell me the way.!
Thank you.
ВeekeeCZ
Try this PLUnion routine, converting PLs to Regions, UNION, then back to PLs.
Spoiler
(vl-load-com)
(defun c:PLUnion ( / *error* adoc oVAR nVAR :AllNewSince
			 ss en i)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (mapcar 'setvar nVAR oVAR)
    (vla-endundomark adoc)
    (princ))
;; Gilles Chanteau- 01/01/07
(defun :Region2Polyline (ss / arcbugle acdoc space
			 n reg norm expl olst blst dlst plst tlst blg pline)
  (defun arcbulge (arc)
    (/ (sin (/ (vla-get-TotalAngle arc) 4))
       (cos (/ (vla-get-TotalAngle arc) 4))))
  (setq	acdoc	(vla-get-ActiveDocument (vlax-get-acad-object))
	space	(if (= 1 (getvar "CVPORT"))
		  (vla-get-PaperSpace acdoc)
		  (vla-get-ModelSpace acdoc)))
  (if ss
    (repeat (setq i (sslength ss))
      (setq reg (vlax-ename->vla-object (ssname ss (setq i (1- i))))
	    norm (vlax-get reg 'Normal)
	    expl (vlax-invoke reg 'Explode))
      (if (vl-every '(lambda (x) (or (= (vla-get-ObjectName x) "AcDbLine")
				     (= (vla-get-ObjectName x) "AcDbArc")))
		    expl)
	(progn
	  (vla-delete reg)
	  (setq olst (mapcar '(lambda	(x) (list x (vlax-get x 'StartPoint) (vlax-get x 'EndPoint)))
			     expl))
	  (while olst
	    (setq blst nil)
	    (if (= (vla-get-ObjectName (caar olst)) "AcDbArc")
	      (setq blst (list (cons 0 (arcbulge (caar olst))))))
	    (setq plst (cdar olst)
		  dlst (list (caar olst))
		  olst (cdr olst))
	    (while (setq tlst (vl-member-if '(lambda (x) (or (equal (last plst) (cadr x) 1e-9)
							     (equal (last plst) (caddr x) 1e-9)))
				olst))
	      (if (equal (last plst) (caddar tlst) 1e-9)
		(setq blg -1)
		(setq blg 1))
	      (if (= (vla-get-ObjectName (caar tlst)) "AcDbArc")
		(setq blst (cons (cons (1- (length plst))
				       (* blg (arcbulge (caar tlst)))
				 blst)))
	      (setq plst (append plst
				 (if	(minusp blg)
				   (list (cadar tlst))
				   (list (caddar tlst))))
		    dlst (cons (caar tlst) dlst)
		    olst (vl-remove (car tlst) olst)))
	    (setq pline (vlax-invoke Space 'addLightWeightPolyline (apply 'append (mapcar '(lambda (x)
											     (setq x (trans x 0 Norm))
											     (list (car x) (cadr x)))
											  (reverse (cdr (reverse plst)))))))
	    (vla-put-Closed pline :vlax-true)
	    (mapcar '(lambda (x) (vla-setBulge pline (car x) (cdr x))) blst)
	    (vla-put-Elevation pline (caddr (trans (car plst) 0 Norm)))
	    (vla-put-Normal pline (vlax-3d-point Norm))
	    (mapcar 'vla-delete dlst)))
	(mapcar 'vla-delete expl)))
  (defun :AllNewSince (ent ss /)
    (while (setq ent (entnext ent)) (if (entget ent) (ssadd ent ss))) ss)
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (setq oVAR (mapcar 'getvar (setq nVAR '(CMDECHO OSMODE))))
  (mapcar 'setvar nVAR '(0 0))
  (if (and (princ "Polylines required, ")
	   (setq ss (ssget ":L" '((0 . "LWPOLYLINE"))))
	   (setq enlast (entlast))
    (progn
      (command "_.REGION" ss "")
      (setq ss nil
	    ss (ssadd)
	    ss (:AllNewSince enlast ss)
	    sn (ssadd))
      (command "_.UNION" ss "")
	(if (and (setq en (ssname ss (setq i (1- i))))
		 (entget en))
	  (ssadd en sn)))
      (if sn (:Region2Polyline sn))
  (*error* "end")
Exactly what i mean.
Thank yo very much Beekee ^_^
