add screen image after startup window
god17169
god17169
Hi guys! just  a question on how you add an image, for exmaple a logo on the screen - its not for titleblock and not the .bmp file that you get during the start up. This sample logo appears when you open an autocad. This shows at the screen after loading the startup screen but when you press escape, run a command, or click anywhere on the modelspace it disappears. Is it added in the template file? It is not really a big matter just something i want to add on the autocad that i  use to look cool. I had been searching for an answer about this for weeks not but i end up on the topic of .bmp file during startup or image inserted for titleblock.
The logo by the way is from ICAL, its a plugin that was installed on the autocad on my previous company, i hope no copyright is being violated,  this is just for academic puroposes.
Thanks in advance to those who might share thier knowledge on this topic.
dgorsman
Sounds like you're asking about a splash screen.  This is a special type of dialog which you don't have direct access to.  You would have to add some programming to show the dialog at program start-up.
Use VSLIDE
