add or minus digit value for digit mtext, leader or block attributes
mruPRQUJ
Message 1 of 23
mruPRQUJ
Attatched lisp can add or minus digit value for digit mtext, leader or block attributes. I wonder if it is possible to modify many objects at one time. Also, can I get spitted lisp? one for mtext ,one for leader, one for block attribute, many thanks. 🙂
Replies (22)
Message 21 of 23
Kent1Cooper
@mruPRQUJ wrote:
Could you please advise me where these stuffs come from? ....
I have no idea, if it's as you say.  I haven't found any way for a width factor to be imposed with formatting code in the text content, other than to edit it.
Kent Cooper, AIA
Message 22 of 23
mruPRQUJ
The lisps works well if the mtext width factor is 1. Otherwise, it did not work well. Is it possible to make changes for this case? thanks a million!
Message 23 of 23
mruPRQUJ
Thank you very much all of you! 🙂
