add more lineweights
Automohan
Automohan
Hello, Is that possible to add more line weights by here program as shown, not in ctb file
thanks
Automohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
DannyNL
Nope.....as far as I know that's not possible.
But assuming you want to have thicker line weights; you can draw a poyline with basically any width/weight you like by changing the width or half width option within the polyline command.
dgorsman
The line weights are not stored as the actual numeric value, but as list of enumerated names.  If I remember correctly you can replace some of them with different values, but you cannot add more entries to the list.
One of my least favorite means of providing line weights.  Plot styles and LW polylines are more effective.
Kent1Cooper
@dgorsman wrote:
....  If I remember correctly you can replace some of them with different values, but you cannot add more entries to the list. ....
You're correct -- HERE is the Help entry for 2018, but the same would be true for earlier versions.  You get to it in the PLOT dialog box, Plot style table (pen assignments) area, pick on the Edit button to the right of the pull-down list, and there's an Edit Lineweights... button in there.
Kent Cooper, AIA
