- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have made an adjustment to an existing dynamic block -> I added an Lookup.
What I'm trying to achieve is that the Lookup property shows up in an attribute.
I succeeded this by adding a field after the block is inserted in the drawing. Since have a lot of drawing which each contain more than a hundred of these blocks it's not an option to add this field separately by each block.
I have tried the lisp routine CopyFieldV1-1 (from LeeMac) this routine does its job very good but in my case the attributes of all existing blocks will be linked to the same field expression of the original block.
Is there a way to show the Lookup property inside the block-attribute?
I have also tried is with different visibility-states but that doesn’t work either for me because I have already an visibility-state inside the block.
Thank you in advance.
