Add limits to lisp routine
jtm2020hyo
Message 1 of 8
jtm2020hyo
I have a lisp example that work pretty good , this lisp draw between blocks base point, but need add limits as promtp options, first-limit should ignore all blocks under a certain distance and second-limit should of ignore all block over a certain diatance. Leave promtp in blank should be understood like "no limits" for both options. Such "certain distance worth" should be inserted by keyboard or click between 2 points in drawing.
Here is the lisp base:
(defun c:connect (/ end fuzz pt ron ss sset)
   (if (and (setq ss (ssget '((0 . "line"))))
            (setq fuzz 0.20)
       (foreach x (setq sset (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
           (foreach p (list (vlax-curve-getstartpoint x)
                            (vlax-curve-getendpoint x)
               (foreach y sset
                   (if
                       (and (not (equal (vlax-curve-getclosestpointto y p)
                                        p
                                        1e-11
                            (or (<= (distance (setq pt (vlax-curve-getstartpoint y)) p)
                                    fuzz
                                (<= (distance (setq pt (vlax-curve-getendpoint y)) p)
                                    fuzz
                            (not (equal x y))
                            (> (cadr p) (cadr pt))
                          (entmod
                              (subst (cons (setq end (if (equal p (vlax-curve-getstartpoint x))
                                                         10
                                                         11
                                           pt
                                     (assoc end (setq ron (entget x)))
                                     ron
   (princ)
Enjoy
Replies (7)
Message 2 of 8
devitg
Please , upload your DWG
Message 3 of 8
jtm2020hyo
this image represents how "connect.lsp" work.  ( lisp file attached) (example drawing attached as requested)
the first code posted apparently does not work anymore for me. but i found an updated version that is attached in this reply.
I need to modify this lisp to ignore block under 2 units of proximity (for example and is an alternative) per each line used to link next block and ignore all block over 3 units  of proximity (for example and is an alternative per each line used to link next block , both options should work at the same time per each polyline generated if I need.
Message 4 of 8
jtm2020hyo
I attached 3 lisp routines that might help to solve this case.
Message 5 of 8
dbhunia
Try this.....
This is combination of both options........that is it connect blocks which is within a range (MIN to MAX).......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 6 of 8
dbhunia
Try this also ........ for all options...... But I did not get the Red Marked point.......
Debashis Bhunia
Message 7 of 8
jtm2020hyo
works perfectly. you are the best. thanks again.
Message 8 of 8
Is there any way to get this lisp to work in a 3D way? For example if I have a lot of points close together and want to create a polyline that limits based on Z value as well as distance?
