Add a Directory to Existing Directory
Todd_Rogers
Mentor Mentor
Message 1 of 8
Todd_Rogers
So, I'm trying to add a directory to an existing directory, but I only know how to create a directory. For example, I'm using this...
(vl-mkdir "C:\\ProgramData\\Autodesk\\ApplicationPlugins\\AECBIMTools.Civil3DTools.bundle\\Contents")
We all know that C:\ProgramData\Autodesk\ApplicationPlugins already exists. So, how do I go about adding the AECBIMTools.Civil3DTools.bundle\Contents to that directory?
Todd Rogers
Civil Administration at Walter P Moore
Replies (7)
Message 2 of 8
ВeekeeCZ
One by one!
(vl-mkdir "C:\\ProgramData\\Autodesk\\ApplicationPlugins\\AECBIMTools.Civil3DTools.bundle")
Message 3 of 8
Todd_Rogers
I'm trying to add \AECBIMTools.Civil3DTools.bundle\Contents to the existing directory C:\ProgramData\Autodesk\ApplicationPlugins
Todd Rogers
Message 4 of 8
ВeekeeCZ
@Todd_Rogers
the issue is not that you need to add a dictionary to the existing one. After all, there is no other way! The issue is that you want to add two of them. But the function isn't smart enough... so create one, then another.
Message 5 of 8
Todd_Rogers
I swear I thought there was a merge-pathnames you can call.
Todd Rogers
Message 6 of 8
komondormrex
actually you can do that in one step like this
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "shell md C:\\ProgramData\\Autodesk\\ApplicationPlugins\\AECBIMTools.Civil3DTools.bundle\\Contents\n")
Message 7 of 8
komondormrex
using et
(acet-sys-command "md C:\\ProgramData\\Autodesk\\ApplicationPlugins\\AECBIMTools.Civil3DTools.bundle\\Contents")
Message 8 of 8
Simon_Weel
In the old days, when Vlisp didn't exist, we used DOSLib for this kind of operations. Still use it.
