Activate last drawing tab created?
DC-MWA
DC-MWA
Hi all,
I have a little routine I'm working on. It uses a specific template to create a new detail drawing.
It works well, but do to the nature of autolisp it ends back in the original drawing where initiated.
I need to activate the drawing created as the last thing the program does. Is this even possible?
So, it creates a drawing and it's automatically named Drawing10.dwg. I need to return to that new drawing tab as the last part of the lisp.
See attached lisp...
ronjonp
Maybe add this to the end?
(vlax-for x (vla-get-documents (vlax-get-acad-object))
  (if (= "DRAWING10.DWG" (strcase (vla-get-name x)))
    (vla-activate x)
DC-MWA
That works, but only if I know it's Drawing10.dwg
Problem I never know what the name will be. All I know is that it's the last created or opened drawing tab.
ronjonp
Maybe something like this 🙂
;; Get current docs open
(vlax-for x (vla-get-documents (vlax-get-acad-object)) (setq chk (cons (vla-get-name x) chk)))
;; Add a doc
(vla-add (vla-get-documents (vlax-get-acad-object)) "test")
;; Activate the doc not in our list
  (or (vl-position (vla-get-name x) chk) (vla-activate x))
DC-MWA
Dude.... You are the man!!
That worked perfect.
Thank you very much!!!
ronjonp
You're welcome .. although there is a simpler way 😉
What does this return?
(vlax-dump-Object (setq o (vla-add (vla-get-documents (vlax-get-acad-object)) "test")))
 If you remove the (princ) from your 'newtemplate' function it will return an object which then can be set current. So your code could be reduced to:
(defun c:det1 (/ o tn)			;path
  (setq tn "F:\\MWA\\templates\\DETAIL_TEMPLATE.dwt") ;start a dwg based on template
  (defun newtemplate (tempname)
    (vla-add (vla-get-documents (vlax-get-acad-object)) tempname)
    ;; RJP removed princ so an object is returned
    ;; (princ)
  (if (setq o (newtemplate tn))
    (vla-activate o)
  (princ)
Or even further:
(defun c:det1 (/ o)			;path
  (if (setq o (vla-add (vla-get-documents (vlax-get-acad-object))
    (vla-activate o)
  (princ)
)(vl-load-com)
DC-MWA
Wow.. Even better.
It seems to go real slow on several of our machines.... any ideas why? (works great on mine...) All very simiar workstations purchased from dell.
