Get value of specific attributes from selected block
DC-MWA
DC-MWA
Hi all,
I have a little portion of code that i want to modify to instead of listing all attribute values from selected block,
to only list two:
COLOR_DESIG and MAT_DESIG
See attached sample code...
Thanks!
_gile
The simplest way is using getpropertyvalue.
(defun c:test3 (/ bnm blks i ent)
  (setq	bnm  (cdr (assoc 2 (entget (car (entsel "\nSelect Block: ")))))
	blks (ssget "_X" (list (cons 2 bnm) '(66 . 1)))
  (repeat (setq i (sslength blks))
    (setq ent (ssname blks (setq i (1- i))))
    (print (strcat "\nCOLOR_DESIG: " (getpropertyvalue ent "COLOR_DESIG")))
    (print (strcat "\nMAT_DESIG: " (getpropertyvalue ent "MAT_DESIG")))
  (princ)
Gilles Chanteau
GileCAD
GitHub
DC-MWA
That was exactly what I needed.
Thank you very much.
DC-MWA
Maybe you can assist me further?
I'm trying to use the information from the attributes to create hyperlinks. It works, but updates all the detail tag blocks in the drawing, not just the one selected???
I have attached the sample code and a sample drawing.
