Message 1 of 1
acdbGetPreviewBitmapFromDwg throws System.AccessViolationException for some files
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been facing an exception while trying to get Thumbnail from a DWG file. Most of the files work correctly, but some of the files do throw System.AccessViolationException on the call to method acdbGetPreviewBitmapFromDwg.
I have tried to explore several options to handle this exception, but found no help on this.
bool ReadThumbnail(std::wstring filename, std::wstring thumbnailPath, RDwgError ^ error)
// acdbGetPreviewBitmapFromDwg depends on hostApp being initialized:
if (!s_hostAppInitialized && Acad::eOk == acdbSetHostApplicationServices(&RealDwg::RealDwgHostApp::Instance()))
s_hostAppInitialized = true;
if (!s_hostAppInitialized)
error->Code = 2;
error->Description = "Host App Not Initialized.";
return false;
HBITMAP hBitmap = NULL;
HPALETTE hPalette = NULL;
char* filenameCharPointer = new char[1024];
wcstombs(filenameCharPointer, filename.c_str(), 1024);
if (!fopen(filenameCharPointer, "r"))
error->Description = "Source file does not exist";
error->Code = 4;
return false;
int bitmapresult;
try
bitmapresult = acdbGetPreviewBitmapFromDwg(filename.c_str(), &hBitmap, &hPalette);
catch (int exception)
std::cout << "Exception occurred : " << exception << std::endl;
if (!bitmapresult)
error->Description = "Could not get preview bitmap from dwg";
error->Code = 3;
return false;
std::cout << "Storing file now" << std::endl;
CImage image;
image.Attach(hBitmap);
image.Save(thumbnailPath.c_str(), Gdiplus::ImageFormatBMP);
std::cout << "File stored successfully" << std::endl;
DeleteObject(hBitmap);
DeleteObject(hPalette);
return true;
Any help this regards.
Umar
