About assoc
About assoc
saitoib
Message 1 of 8
About assoc
saitoib
Hi all.
In the following code, the ent in line A is
ent = (-3 ("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1)))
I get an error on line B. What is wrong?
What is wrong?
Thank you.
(defun _sort_panel ( ss / nn i id ent lay panel_list)
  (setq nn (sslength ss))
  (setq i 0)
  (repeat nn
    (setq id (ssname ss i))
    (setq ent (assoc -3 (entget id '("XData")))) ;A
    (setq ent (assoc 1070 ent)) ;B
Saitoib
Replies (7)
Message 2 of 8
ВeekeeCZ
(cdr ent) missing?
Message 3 of 8
cadffm
[Typos edited - the third time :-/]
after line a the value is ent = (-3 ("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1)))
same list, another formatting:
( -3
So, you have 2 items inside and the list isn't a valid association list (a list with nested listes inside only)
Command: (cdr (-3 ("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1))))
(("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1)))
Now, there are only ONE list inside, but the assoc-element is "xdata" - what you don't want.
Command: (cadr '(-3 ("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1))))
Not only lists inside
Command:: (cdadr '(-3 ("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1))))
((1040 . 90.0) (1040 . 4.1) (1070 . 1))
Now, only lists inside (valid association list) and you can use ASSOC!
Command:: (assoc 1070 (cdadr '(-3 ("XData" (1040 . 90.0) (1040 . 4.1) (1070 . 1)))))
(1070 . 1)
Sebastian
Message 4 of 8
ВeekeeCZ
Removed.
Message 5 of 8
cadffm
thx you, but I was faster 🤣
I had to edit my edit <crazy> 😐
Sebastian
Message 6 of 8
saitoib
@cadffm
Thank you very much.
I understand now.
Saitoib
Message 7 of 8
diagodose2009
Please you upload a Sample.Dwg with entities + Xdata..
Can you share a your Drawing.dwg?
Message 8 of 8
saitoib
Would this be of any help to you?
Saitoib
