A couple of newbie lisp questions / requests
h_s_walker
Mentor Mentor
Message 1 of 40
h_s_walker
My company is soon going to be getting LT2025 after being stuck on LT2016 for ages.
Now I know if I want settings to load up everytime I need to put them in the *doc.lsp file.
What do I need put in the lisp file to change the following?
MTEXTCOLUMN 0
HPANNO 1
PASTESPECMODE 1
Those 3 will do for starters.
OK next request
We get sent drawings from clients all the time and I use the RENAME command to put "XCLIENT " in front of every entity so that all client stuff gets shoved to the bottom of the dialog boxes.
Is there a lisp which can run through the renaming of everything in the client drawing without me have to go through each and every group of items?
Howard Walker
Left Handed and Proud
Accepted solutions (3)
Replies (39)
Message 21 of 40
MrJSmith
@ronjonp I thought about that, but figured I should just give him what he asked for 😉
Message 22 of 40
pendean
Community Legend
Community Legend
Message 23 of 40
MrJSmith
@pendean I think you misunderstood him, he doesn't want to rename the files but rather the objects inside ACAD i.e. blocks and layers.
Message 24 of 40
pendean
Community Legend
Community Legend
Thanks for that.
Message 25 of 40
ronjonp
@MrJSmith wrote:
@ronjonp He wanted all the named objects as listed in the RENAME command. That only handles the tables. You still have to do the dictionaries.
I'm aware of that .. this was all the effort I wanted to put into this. 😎
I still think this is a much simpler solution: Another way to solve this sorting problem is to have a template and make all your layers blocks etc ...
Message 26 of 40
ronjonp
Why wouldn't you add it? It's a simple WCMATCH check.
Message 27 of 40
paullimapa
for some reason when it comes to textstyles this line of code:
(vl-catch-all-apply '(lambda () (vla-put-name it (strcat prefix (vla-get-name it)))))
Would yield following error
; error: ActiveX Server returned an error: Type mismatch
I had to resort to the old rename command:
(vl-cmdf "_.-Rename" "_Style" (vla-get-name it) (strcat prefix (vla-get-name it)))
Paul Li
IT Specialist
@The Office
Message 28 of 40
john.uhden
@paullimapa ,
Have you tried (vlax-invoke it 'get-name ....))?  Or even vlax-invoke-method?
I have found that for various species of the vla* family, certain varieties will work but others not.
John F. Uhden
Message 29 of 40
paullimapa
Since the setpropertyvalue method works I decided to code it like this:
       (if (eq "textstyles" table) ; add filter out to run different code for textstyles
        (if (not (tblsearch "style" (strcat prefix (vla-get-name it)))) ; add check if rename textstyle doesn't exist
         (setpropertyvalue (vlax-vla-object->ename it) "Name" (strcat prefix (vla-get-name it))) ; this works on textstyles
        (vl-catch-all-apply '(lambda () (vla-put-name it (strcat prefix (vla-get-name it))))) ; this doesn't work on textstyles
Paul Li
IT Specialist
@The Office
Message 30 of 40
h_s_walker
@MrJSmith @ronjonp Thanks I'll try those when I get into work
@pendean No I just needed to change my username, because my work will use my old one for LT 2025
Howard Walker
Message 31 of 40
Sea-Haven
Just my $0.05 I stay away from acaddoc.lsp etc but rather have a custom lisp with all my start up code, you just do Appload and add to the "start up suite" it will run when you open a dwg.
Message 32 of 40
h_s_walker
@Sea-Haven Yeah I am thinking of going that route.
Howard Walker
Message 33 of 40
h_s_walker
@MrJSmith Yep that is almost perfect as has been mentioned elsewhere it doesn't work on text styles
@paullimapa Where would I put your little snippet of code to make it work?
Howard Walker
Message 34 of 40
paullimapa
attached is my modified version...
Paul Li
IT Specialist
@The Office
Message 35 of 40
h_s_walker
@paullimapa Works perfectly. Cheers
@ronjonp Since the dinosaurs started crawling out of the primordial ooze
Howard Walker
Message 36 of 40
paullimapa
It was a group effort…cheers!!!
Paul Li
IT Specialist
@The Office
Message 37 of 40
Sea-Haven
Glad to help, we ran a server so any updates to the autoload were straight away available. No customizing code on each pc.
Message 38 of 40
MrJSmith
@paullimapa Interesting. Turns out the textstyles name property is read only. I've hence updated my code to include your fix.
Message 39 of 40
paullimapa
Yes, very strange that it's only the case with textstyles. But glad that at least the setpropertyvalue method works.
Paul Li
IT Specialist
@The Office
Message 40 of 40
Sea-Haven
Just a comment comparing Bricscad with LT2025 does not have the problem of missing lisp functions a definite drawback. Possibly better pricing also.
