Connect Autolisp file to my Dialog box file
christian_paulsen98V29
Message 1 of 12
Hello! I recently just created a dialog box which i think I've got looking almost exactly how i want it to look.
Now i am trying to create the Autolisp file that calls forward the dialog box, and then performs actions based off of the users input.
At first the dialog box was popping up, and you could check/uncheck the boxes and also type in the text field. Now when i try to open the dialog box it pops up but then instantly closes. I'm getting the error on my command line "; error: too many arguments".
So i guess the first part of fixing this would be to stop it from instantly closing.
The second part is making it functional. The purpose of this dialog box is to rename my current layout based off of which options are selected in the dialog window. Ideally you would check the boxes, then based off of what is checked it would then get passed down to the text field, then when you click ok whatever is in the text field would then get passed to your current tab name.
I will post both the dcl code and lisp code below. Please give me any advice you may have, all input is appreciated.
layoutrename : dialog {
 label = "Edit Layout Title" ;
	: row {
		:boxed_row {
		label = "Select Layout Options" ;
			: toggle {
			key = "tb1" ;
			label = "Plan" ;
			value = "1" ;
			: toggle {
			key = "tb2" ;
			label = "Elevations" ;
			: toggle {
			key = "tb3" ;
			label = "Sections" ;
			: toggle {
			key = "tb4" ;
			label = "Details" ;
			: toggle {
			key = "tb5" ;
			label = "Isometrics" ;
			: toggle {
			key = "tb6" ;
			label = "Fabrications" ;
	: row {
		: edit_box {
		key = "eb1" ;
		label = "Layout Name :" ;
		edit_width = 60 ;
	ok_cancel ;
(defun C:layoutrename ()
	(setq layoutname "test")
	(setq dclfilename "layoutrename.dcl")
	(setq dialogname "layoutrename")
	(setq dcl_id (load_dialog dclfilename))
	(new_dialog dialogname dcl_id)
	(action_tile "tb1" "(setq layoutname (strcat layoutname "Plan"))")
	(action_tile "tb2" "(setq layoutname (strcat layoutname "Elevations"))")
	(action_tile "tb3" "(setq layoutname (strcat layoutname "Sections"))")
	(action_tile "tb4" "(setq layoutname (strcat layoutname "Details"))")
	(action_tile "tb5" "(setq layoutname (strcat layoutname "Isometrics"))")
	(action_tile "tb6" "(setq layoutname (strcat layoutname "Fabrications"))")
	(set_tile "eb1" layoutname)
	(action_tile
	"cancel"
	"(done_dialog)"
	(action_tile
	"accept"
	"(command "-layout" "r" layoutname "")"
	"(done_dialog)"
	(start_dialog)
	(unload_dialog dcl_id)
Replies (11)
Message 2 of 12
paullimapa
These are the modifications that I made to both your DCL and LSP:
1. DCL - instead of toggle buttons you should use radio buttons so that only the current choice is selected. I commented out your lines of code and entered new ones:
//		:boxed_row {
		:boxed_radio_row {
//			: toggle {
      : radio_button {
			key = "tb1" ;
			label = "Plan" ;
			value = "1" ;
//			: toggle {
      : radio_button {
			key = "tb2" ;
//			: toggle {
      : radio_button {
			key = "tb3" ;
//			: toggle {
      : radio_button {
			key = "tb4" ;
			label = "Details" ;
//			: toggle {
      : radio_button {
			key = "tb5" ;
//			: toggle {
      : radio_button {
			key = "tb6" ;
2. LSP - assuming your dcl file is located under one of the Options>Files>Support File Search Paths, then the following changes should be made:
a. Localize variables - this can be done once you've finished troubleshooting the code replacing the following line:
With this:
(defun C:layoutrename (/ dialogname dclfilename layoutname layoutname stid) ; localize variables
b. Add this line to check if currently in Model tab which cannot be renamed then switch to layout tab:
  ; if in Model switch to layout since model tab cannot be renamed
  (if(not(zerop(getvar"tilemode")))(setvar"tilemode"0))
c: Quotes listed in action_tile statements need to be prefixed using backslash as the escape key so: " need to be: \"
d: edit_box key "eb1" should reflect radio_button selection
e: instead of replacing the layoutname variable I added a new one layoutnamenew so layoutname string can be preserved
So replace the following lines of code:
With these:
  (set_tile "eb1" (setq layoutnamenew (strcat layoutname "Plan"))) ; initial setting
	(action_tile "tb1" "(set_tile \"eb1\" (setq layoutnamenew (strcat layoutname \"Plan\")))")
	(action_tile "tb2" "(set_tile \"eb1\" (setq layoutnamenew (strcat layoutname \"Elevations\")))")
	(action_tile "tb3" "(set_tile \"eb1\" (setq layoutnamenew (strcat layoutname \"Sections\")))")
	(action_tile "tb4" "(set_tile \"eb1\" (setq layoutnamenew (strcat layoutname \"Details\")))")
	(action_tile "tb5" "(set_tile \"eb1\" (setq layoutnamenew (strcat layoutname \"Isometrics\")))")
	(action_tile "tb6" "(set_tile \"eb1\" (setq layoutnamenew (strcat layoutname \"Fabrications\")))")
f. The dialog needs to be closed first and then you can perform a layout rename
g. Clicking the cancel key vs accept should return different values
h. Then based on if dialog is accepted then run the layout rename command
So change the following lines of code:
	(action_tile
	"cancel"
	"(done_dialog)"
	(action_tile
	"accept"
	"(done_dialog)"
	(start_dialog)
To these:
	(action_tile
	"cancel"
	"(done_dialog 0)"
	(action_tile
	"accept"
	"(done_dialog 1)"
	(setq stid (start_dialog)) ; save return dialog status per clicked done_dialog value
  (if (= stid 1) ; chk if ok clicked
   (if(not(member layoutnamenew (layoutlist))) ; chk if layoutname exists
	  (command "_.-Layout" "_R" (getvar "ctab") layoutnamenew) ; then rename current layout
    (alert (strcat "Current Layout Name: \n\t[" (getvar "ctab") "]\nCannot be Renamed to an Existing Layout Name: \n\t[" layoutnamenew "]")) ; else show
 (princ) ; clean exit
Paul Li
IT Specialist
@The Office
Message 3 of 12
Im on my phone right now so i cant plug in the lisp and test it.
However i can tell you that the radio buttons will not work. Its not always just one of those options. Sometimes it is a combination of multiple options. For example "Sections Elevations Isometrics".
I was going to change the code to add things in with an "&" sign before them like "(strcat layoutname "& Elevations")" or "(strcat layoutname "& Isometrics")". The only issue with that is that if it is the first item in the list then the "&" sign is not necessary.
Message 4 of 12
paullimapa
In that case I've changed the dcl file back to toggle buttons and modified the lisp.
The code now includes a subfunction set_eb1 that's used by the action statements by all the toggle buttons.
Depending on if the toggle button is checked then add the selected name if not already done vs unchecked then  remove the selected name. Then it'll define an updated layoutname for the rename.
Give this a shot.
Paul Li
IT Specialist
@The Office
Message 5 of 12
MrJSmith
@paullimapa You really went all out!
@christian_paulsen98V29 It is better to save your variables at the done_dialog phase and then run commands afterwards based on the variables (as paullimapa did). My only other suggestion would be to write the DCL in LISP, that way you don't have to manage two separate files for your program.
Message 6 of 12
How do you write the dcl in lisp? This was my first attempt at anything to do with dialog boxes.
Message 7 of 12
paullimapa
Read all about it in my Jan article on Dialog Fun Facts:
AUGIWORLD by AUGI, Inc. - Issuu
You can also load and run the attached (DCL2LSP) function and select a dcl file & it'll convert it into lisp code for you to load with your lsp program.
Paul Li
IT Specialist
@The Office
Message 8 of 12
john.uhden
@christian_paulsen98V29 ,
One thing I see is in your action_tiles.
Every thing in DCL requires a string, so when you want to add a string to an action_tile action you must "Esc" the quoted string by adding a backslash before each of its quotes...
EDITED
Not:
But:
(action_tile "tb1" "(setq layoutname (strcat layoutname \"Plan\"))")
John F. Uhden
Message 9 of 12
I was wondering why there was so many quotations. I knew there was some kind of rule but i couldnt figure out the exact one.
Message 10 of 12
john.uhden
Take look again.  I edited my response to correct an error.
John F. Uhden
Message 11 of 12
Sea-Haven
Have a look at this for convert a dcl to lsp. Compliments to RLX.
Message 12 of 12
MrJSmith
