Visual LISP, AutoLISP and General Customization
a code to save all the block in the file to individual dxf with its block name
13 REPLIES 13
Message 1 of 14
formobalaji
835 Views, 13 Replies
i need a autolips code to save all the block in the file to individual dxf with its block name
13 REPLIES 13
Message 2 of 14
paullimapa
in reply to: formobalaji
this app will let you select the blocks you want and export them out as dwg
https://apps.autodesk.com/ACD/en/Detail/Index?id=6861263512373641535&appLang=en&os=Win32_64
Paul Li
IT Specialist
@The Office
Message 3 of 14
daniel_cadext
You can do this in ARX or .NET
I’m using Python just because it’s easy to prototype quick stuff
https://github.com/CEXT-Dan/PyRx
import PyRx as Rx
import PyGe as Ge
import PyGi as Gi
import PyDb as Db
import PyAp as Ap
import PyEd as Ed
import traceback
def PyRxCmd_doit():
    try:
        db = Db.curDb()
        bt = Db.BlockTable(db.blockTableId())
        for name, id in bt.toDict().items():
            btr = Db.BlockTableRecord(id)
            if btr.isLayout():
                continue
            if btr.isAnonymous():
                continue
            if btr.isFromExternalReference():
                continue
            if btr.isFromOverlayReference():
                continue
            if(name.startswith("A$")):
                continue
            doutDb = db.wblock(id)
            outDb.dxfOut("E:\\temp\\{}.DXF".format(name))
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 4 of 14
formobalaji
in reply to: daniel_cadext
THANKS FOR REPLY
BUT I NEED IN AUTOLISP
Message 5 of 14
daniel_cadext
maybe this
https://blog.draftsperson.net/wblock-all-lisp-routine/
just replace the extension from .dwg to .dxf
I didn't try though
Message 6 of 14
diagodose2009
║ Nr. blocuri =35
║ Format-nume BlocK = *
║ Ora si data =
║ Cale pe disc = C:\Vlaxcompil\0User\
║ Timpul de scriere = *
║ Lista numelor blocurilor este
║ si blocuri sunt   salvat\343 in acelasi
║ director << Here you all names>
║ NORD1
║ STILBET
║ PUTAMER
║ PUNCT
║ CVCAN
║ GAGER
║ HIDRANT
║ CVGAZE
║ CVTEL
║ PTSTALP
║ STLEA
║ STELLIN
║ STLEMN
║ STILLMN
║ STTEL
║ STELCF
  • 😃I have the programe , export many blocks to path, but with extension Dwg.
  • If you need ,forced to DXF, then you send  the pm. to me
00)Always you save the "CurrentDrawing.dwg" , where your need path for store all blocks/dwg
02You my explorer-picture "topGradRepeat.jpg:
03)You open "anexa1_35_landscapeb5_2k.dwg"
04)You appload "pp_libcache_block_plugin.vlx"
06)You enter the command (C:q2) pr Q2[enter]
  • You need the full-source(directly.lsp100%) then we can collaborate online
  • or you change the language to english, germany, polish for pp_libcache_block_plugin.vlx
Message 7 of 14
paullimapa
Try this: DwgACCBlk2Dxf.lsp
It'll first export all the blocks as dwgs.
Then it'll convert them to dxfs.
So you'll end up with both dwgs & dxfs.
Paul Li
IT Specialist
@The Office
Message 8 of 14
komondormrex
check the following. will save all drawing blocks to drawing path\All_Blocks_DXF\ in DXF format. if block with same name already is in directory it will be skipped.
(defun c:all_dwg_blocks_to_dxf (/ blocks_dxf_directory block_count block_name block_dxf_name)
	(setvar 'cmdecho 0)
	(setq blocks_dxf_directory (strcat (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'path) "\\All_Blocks_DXF")
	      block_count 0
	(if (null (vl-file-directory-p blocks_dxf_directory))
		  (vl-mkdir blocks_dxf_directory)
	(vlax-map-collection (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
		'(lambda (block)
			(and
			  	(setq block_name (vla-get-name block))
				(snvalid block_name)
				(null (findfile (setq block_dxf_name (strcat blocks_dxf_directory "\\" (setq block_name (vla-get-name block)) ".dxf"))))
				(setq block_count (1+ block_count))
				(command "_-wblock" block_dxf_name "" block_name)
	(setvar 'cmdecho 1)
	(princ (strcat "\nTotal " (itoa block_count) " blocks saved to \"" blocks_dxf_directory "\" directory"))
	(princ)
Message 9 of 14
formobalaji
in ABOVE CODE need ADDITIONALLY ONE to automatically explode all the blocks before SAVING
Message 10 of 14
paullimapa
Lots of options by just doing a simple search like this one
https://www.cadtutor.net/forum/topic/44634-explode-all-blocks/
Paul Li
IT Specialist
@The Office
Message 11 of 14
komondormrex
added
(defun c:all_dwg_blocks_to_dxf (/ insert_sset exploded_list blocks_dxf_directory block_count block_name block_dxf_name)
	(if (setq insert_sset (ssget "_x" '((0 . "insert"))))
		(foreach insert (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex insert_sset))))
			(setq exploded_list (list insert))
			(while exploded_list
				(foreach insert exploded_list
					(setq exploded_list (append exploded_list (vlax-invoke insert 'explode))
						  exploded_list (vl-remove insert exploded_list)
					(vla-erase insert)
				(setq exploded_list (vl-remove-if-not
										'(lambda (object) (= "AcDbBlockReference" (vla-get-objectname object)))
										 exploded_list
	(setvar 'cmdecho 0)
	      block_count 0
		'(lambda (block)
			(and
	(setvar 'cmdecho 1)
	(princ)
Message 12 of 14
formobalaji
SORRY
ACTUALLY WHAT IAM LOOKING FOR IS, AFTER EXTACTING THE BLOCKS AND SAVING IT AS SEPARTED DXF, I NEED TO EXPLODE THE SKETCH IN THE NEW CREATED DXF
Message 13 of 14
komondormrex
you'd better post an example of your block and show what you need to be exploded.
Message 14 of 14
formobalaji
NEED TO SAVE THE BLOCKS IN DXF V2010
AutoCAD Inside the Factory
