Hi:
I tried to use the AcPublishReactor and AcDMMReactor to control the data of
a published DWF file it worked fine with 2D dwf's but i failed to do it with
3dDWF.So can any one tell me how could i edit the 3ddwf data of a dwg file
during the publishing operation as i want to change some of the default
values.i.e i want to add a certain name to the entity instead of the handle.
How could this be done?Hint i am using Autocad2006 where 3dDWF is supported
through the 3ddwfpublish command.
Thanks in advance.
Nermeen Bakr
Project Manager
MCS (Modern Computing Services)
Website: http://www.mcsoil.com
Phone: +2 02 4036520 /+202 4051129
Fax: +2 02 4040503
