; 1 form loaded from #<editor ""
Message 1 of 11
Hi I was writing this code for a hw but I get the error ; 1 form loaded from #<editor "G:/CAD/HW 8/LBox.lsp"> when i try to load the code up.
; LBOX.lsp
(defun c:lbox ()
; Turn command echo and object snap off, and blip mode on
(setq scmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq sblip (getvar "blipmode"))
(setvar "blipmode" 1)
(setq sosmd (getvar "osmode"))
(setvar "osmode" 0)
(setq 3dosmd (getvar "3dosmode"))
(setvar "3dosmode" 0)
(setq dyucs (getvar "ucsdetect"))
(setvar "ucsdetect" 0)
; Input data for part
(setq pt1 (getpoint "\n Locate Lower Left Corner Point"))
(setq pt2 (getpoint "\n Locate Upper Right Corner Point"))
(setq H (getreal "\n Input Height of Part"))
(setq D (getreal "\n Input Diameter of Hole"))
; Change current color
(command "color" "red")
; Determine width of part
(setq A (- (car pt2) (car pt1)))
; Set locations of additional points
(setq pt3 (list (car pt2) (cadr pt2) (- H)))
(setq pt4 (list (car pt2) (cadr (/ (+ (cadr pt1) (cadr pt2)) 2)) (- H)))
(setq pt5 (list (car pt2) (car pt1) (- H)))
; Create solid
(command "box" pt1 pt3)
(setq e1 (entlast))
(command "arc" "c" pt4 pt5 pt3)
(setq e2 (entlast))
(command "line" pt3 pt5 "")
(command "region" e2 "l" "")
(command "extrude" "l" "" A)
(command "union" e1 "l" "")
(setq e3 (entlast))
(setq pt6 (list(car pt1) (cadr (/ (+ (cadr pt1) (cadr pt2)) 2))(- (/ (- (H A) 2)))))
(setq pt7 (list (car pt2) (cadr (/ (+ (cadr pt1) (cadr pt2)) 2)) (- (/ (- (H A) 2)))))
(command "color" "green")
(command "cylinder" pt6 (/ D 2) "A" pt7)
(command "subtract" e3 "" "l" "")
(setq pt8 (list (car pt1) (cadr pt1) (- H)))
(command "color" "blue")
(command "ucs" 3 pt8 pt5 pt1)
(command "text" (list 0.1 0.1) 0.3 0 "Robin")
(command "ucs" "w")
(command "vpoint" (list 1 -1 1))
(command "hide")
(setvar "blipmode" sblip)
(setvar "cmdecho" scmde)
(setvar "osmode" snp)
(setvar "3dosmode" 3dosmd)
(setvar "ucsdetect" dyucs)
Replies (10)
Message 2 of 11
ВeekeeCZ
Home assignment, right?
Just pointing on some errors...
; Create solid
(command "box" pt1 pt3) ; something missing
(setq e1 (entlast))
(command "arc" "c" pt4 pt5 pt3) ; probably wrong calculation leads to R=0
... and probably more...
Message 3 of 11
is that why i would get the load error i cant really see any other error messages until this one is resolved i have never been good at coding so one error message at a time would be grateful.
Message 4 of 11
ВeekeeCZ
Well, "; 1 form loaded from #<editor "<Untitled-4> loading...">" is not really an error, that's the information that code was loaded.
Go to the cad, and run your program typing LBOX, then I receive the "Command: bad argument type: consp 476.868" error, which the first line I've bold before...
Message 5 of 11
Kent1Cooper
Some other issues:
Same problem @ВeekeeCZ pointed out about the setting of pt4, and another:
But I don't know about the error message described -- whether fixing those issues identified will also fix that, I couldn't say.
Kent Cooper, AIA
Message 6 of 11
ok i fixed up the program but i still get and error when i run it ;error: bad argument type: consp 5.0
;Program to create a solid L-shaped object with cylindrical bottom and horizontal hole
;Robin
; LBOX.lsp
(defun c:lbox ()
;Turn command echo and object snap off, and blip mode on
(setvar "osmode" 0)
;Input data for part
(setq pt1 (getpoint "\nLocate Lower Left Corner Point"))
(setq pt2 (getpoint "\nLocate Upper Right Corner Point"))
(setq H (getreal "\nInput Height of Part"))
(setq D (getreal "\nInput Diameter of Hole"))
;Change current color
;Determine width of part
;Set locations of additional points
(setq pt4 (list (car pt2) (cadr (/ (+ (cadr pt5) (cadr pt3)) 2)) (- H)))
;Create solid
(setq e1 (entlast))
(setq e2 (entlast))
(setq e3 (entlast))
(setq pt6 (list(car pt1)(cadr pt4)(/ (- H A) 2)))
(setq pt7 (list(car pt5)(cadr pt4)(/ (- H A) 2)))
(command "text" (list 0.1 0.1) 0.3 0 "ROBIN")
(command "ucs" "w")
(command "hide")
;End of program
Message 7 of 11
Kent1Cooper
You didn't fix it all yet.  The first issue @ВeekeeCZ pointed out is still there:
The (cadr) function returns the second item in a list.  Your use there is as though it's supposed to supply  the Y coordinate, but it's used for extracting  Y coordinates from point coordinate lists.  The expression you're giving it as an argument results in a number, not a list.  And sure enough, the error message means that some function that is expecting to get a list  is getting a number  instead, and I'll bet that's the one.  Without evaluating too closely, removing the red parts should fix it, because what remains between them looks like it should be a viable Y coordinate.
Kent Cooper, AIA
Message 8 of 11
made more progress the will run a little more will give me everything but the cylinder cut and gives an error of Not enough free RAM for HIDE --some lines will be hidden incorrectly. ;error AutoCAD variable setting rejected: "osmode" nil
;Robin
; LBOX.lsp
(defun c:lbox ()
(setvar "osmode" 0)
(setq pt5 (list (car pt2) (cadr pt1) (- H)))
(setq pt4 (list (car pt2) (/ (+ (cadr pt2) (cadr pt5)) 2) (- H)))
;Create solid
(setq e1 (entlast))
(setq e2 (entlast))
(setq e3 (entlast))
(setq pt6 (list (car pt1) (cadr pt4) (/ (- H A) 2)))
(setq pt7 (list (car pt5) (cadr pt4) (/ (- H A) 2)))
(command "ucs" "w")
(command "hide")
;End of program
Message 9 of 11
dbroad
I'm curious about how the teacher who assigned this project will react when he discovers this student has turned in group work and publicized a solution to the rest of the class that short circuits most of the learning process for them.
Architect, Registered NC, VA, SC, & GA.
Message 10 of 11
1: its past due so i already handed in my mess of a code
2: I'm trying to learn and figure out why it is wrong.
3: I am allowed to ask my peers to trouble shoot. Which I already did and they have no idea why it won't make the cylinder.
Message 11 of 11
dbroad
In order to build a class learning community, I think the peers your teacher may have been thinking about were your fellow students rather than a public forum.  Get the teacher to post here and I would be very willing to contribute, if that helps.
