1 form loaded from #<editor "<Untitled-0> loading..."> AutoLISP error
xxpochita123
xxpochita123
I was trying to import my csv file using this line of code:
(setq f (open "C:\\Users\\김민정\\A1B_Simulation_01.csv" "r"))
And when I run it, this message shows up in the console:
; 1 form loaded from #<editor "<Untitled-0> loading...">
Just a bit of background:
  • This is not the first time I wrote an AutoLisp code. I've written one or two routines before and it ran successfully.
  • Now, I'm creating a new one (using the same code but different file to import, and other few/minor changes) on a new file but I still get that message. It seems like AutoCAD doesn't read my file properly.
  • In this new routine that I'm making, I've only written one line so far (since it doesn't work properly).
I've been stuck here for hours so I'd really appreciate it if someone could help me out as soon as possible. Thank you!
Moshe-A
@xxpochita123 hi,
this is not a normal respond to opening text file for read (should be FILE type) so i bet there is something else wrong in your code that causing this. Can you post the whole code for review?
Moshe
xuantientutungXUK6E
post your code.
paullimapa
I wonder if it’s these characters
김민정
that may be causing problems.  What if you placed the csv file in a location with only English character folder names?
Paul Li
IT Specialist
@The Office
