Roundabout behavior with 6 Arms
- Mute
- Permalink
- Report
Need help with a strange roundabout issue in C3D 2020 & 2022.
6 arms in roundabout. VehicleTrack creates 2D model shows all 6 legs/arms, Heads up display table counts as 6 but Roundabout Properties in VTrack shows only 5. The corridor model is created fine also, with 6 arms/ baselines. When recreating to try again a different arm may be missing depending on the order or the arms you pick during creation. Also, Roundabout does not come into C3D from Infraworks when you try that workflow, even though roundabout looks perfect in Infraworks
What conditional constraints or out of bound values cause an arm not to be created ? Since heads up display says there is 6 and corridor model has 6 . If VehTrack detects a design issue and does not create that arm as shown in Properties then why is it displayed in the 2 D model and why is the full corridor model built and why do the heads up display tables all show in dwg ?
