What do the icons (circled below) represent??
Solved by viji.kumar. Go to Solution.
Hi Neil
The first 2 are icons that are used to invoke Predictive Turning. Predictive Turning is an AutoDrive feature that displays the limits of the vehicle path from the last position placed and the limits of body or wheel envelope from the ghosted unselected position. Also known as “Cat’s Whiskers”.
The first displays the limits for forward movement and the second for reversing. The last icon does not have a documented function and is a legacy feature. The AVT development team are aware of that.
I hope that helps.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I'd just like to point out that here in 2021 if you hover over the icons, they STILL DO NOT TELL YOU WHAT THEY DO.
....6+ years and the obvious move to add tool-tips has still not occurred. You can still find out within the help file, though there is no indication whatsoever as to what the icons are so you'll need to read the lot to decrypt it!
...Luckily, if you do toggle the icons, you can pretty much tell what they do!
