Hi @pics.munmun, I hope you're doing fine. You can do so by using this option:
![ecfernandez_0-1659978427574.png ecfernandez_0-1659978427574.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1101646iD9ED8E5E77A9E846/image-size/medium?v=v2&px=400)
Then, a new window will prompt, and you'll have to select the vehicle of your preference and if you want to print the template in a PDF or the drawing.
![ecfernandez_1-1659978546197.png ecfernandez_1-1659978546197.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1101648i70E74AEB909AF53C/image-size/medium?v=v2&px=400)
Go through the wizard's steps and define the settings according to your needs, and finally, you'll get something like this:
![ecfernandez_2-1659978592731.png ecfernandez_2-1659978592731.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1101649i430EBE269D327823/image-size/medium?v=v2&px=400)
I hope this helps.
Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
