I need to use these 2 type of planes, Boeing 777-9x and Airbus 350-1000 but unfortunately they're not in the airplane database. Is there any new update with these planes, or did somebody make these modells?
Is it possible to make them in vehicle wizard for a normal user, not an expert? Has somebody tried to creata a plane?
Thank you for your help!
Andras
Solved by ecfernandez. Go to Solution.
If you have complete information about this airplane. You can "edit a copy" of the models preloaded in vehicle tracking and change the dimensions that are different. Try it selecting the planes that are similar to the ones you need.
I hope this helps!
Best regards!
Thank you @ecfernandez
We have succesfully made the missing planes.
But actually it would be great if autodesk would refresh the plane database. They haven't since 2016...
Hi @gyalay-korpos.andras, good to know you solved it!
Happy to help! 🙂
Let's wait for the updates you mentioned. Best regards!
