Vehicle Tracking Forum
Welcome to Autodesk’s Vehicle Tracking Forums. Share your knowledge, ask questions, and explore popular Vehicle Tracking topics.
3 Point Turns
4 REPLIES 4
levberez
412 Views, 4 Replies
3 Point Turns
I've used Transoft's Autoturn before and you could do a seamless 3 or 4 point turn for semi-trailers.
I can't seem to figure out how to do the same in Vehicle Tracking and none of the video tutorials show more complex moves.
Can someone point me in the right direction, or offer some hints please.
Thank you,
LB
4 REPLIES 4
levberez
in reply to: levberez
Nevermind, I finally figured it out but it's very buggy /touchy, and it won't let you turn the wheels while the truck is stationary which makes the maneuvering excessively long & drawn out.
Also, make sure you turn off the Limit Forward Turn Rate & Limit Reverse Turn Rate options, which seem to be turned on automatically.
brian.strandberg
There is a way to do that - I recorded a quick video here:  https://youtu.be/LMc5PYj2bWI
Hope this helps.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Uploaded by Brian Strandberg on 2024-06-27.
levberez
in reply to: brian.strandberg
Thank you Brian, that's very helpful. I couldn't figure out what the Spot option actually did, so seeing it being used is a game changer. I also never notice the reverse button since it's way in the back rather than being an option next to the forward button. I will definitely do a few practice sessions while re-watching your video.
Much appreciated.
NateSarles
@levberez, Don't forget to mark a solution if you have found the answer you are looking for!
It helps keep the threads tidy!
C3D 2025.1
Sr. CAD Technician
Windows 11, 32 GB RAM
11th Gen Intel(R) Core(TM) i7-11370H
