VBA string replace mtext
jorgen.fidjeland
jorgen.fidjeland
So I have a autocad 2d drawing with a lot of mtext. I have to change all instances of ":" to "-". Doing this manually would take a long time, so I thought of doing it with VBA.
I'm not asking for a full code, but some input on wether this is possible or not? All I have found about this on the internet is about making a new mtext, not editing existing mtexts.
So, my pseudo-code I imagine is something like this
Loop all objects
if(type=mtext)
       mtext.text = str_replace(":","-",mtext.text)
end if
This is first time vba in acad. Have done some before in excel and access..
Thanks in advance
Ed__Jobe
Sure, its possible, but have you tried the FIND command?
Ed
How to post your code.
naresh_kalyan
Hi all,
I have tried to get the MText string of a Mtext of AutoCAD 2016 using VBA. Here the case is, I could able to get "Text" but not MText. Kindly anyone help me. I'm bit new to AutoCAD customization.
Set oSset = .Add("$MTexts$").
Dim mode As Integer
Dim corner1(0 To 2) As Double
Dim corner2(0 To 2) As Double
mode = acSelectionSetCrossing
corner1(0) = 3.1325: corner1(1) = 2.1875: corner1(2) = 0 ''2 3/16
corner2(0) = 3.6315: corner2(1) = 3.5625: corner2(2) = 0
oSset.Select mode, corner1, corner2
please help me...
Regards
Naresh Kalyan
norman.yuan
Well, your code is not relevant to why you was able to get Text, but not MText. It just selects anything inside/crossed by a window. Are you sure there are MText, or any entity for that matter, being selected in the SelectionSet? Since you did not set selecting filter, it is not guaranteed that only MText entities are selected. So, you need to find out if an entity in the SelectionSet is the type of entity you target:
'' Assume the selection does select some entities
'' which may or may not be all MText entities
OSset.Select mode, corner1, corner2
Dim ent As AcadEntity
Dim mtxt As AcadMText
Dim count As Integer
For Each ent In oSset
    If TypeOf ent Is AcadMText Then
        Set mtxt=ent
        HandleMText mtxt
        count = count +1
Next
MsgBox count & "MText entities have been handled."
Private Sub HandleMText(mtext As AcadMText)
    '' Do whatever with the MText
End Sub
Norman Yuan
Drive CAD With Code
naresh_kalyan
Thank you for the help with in a short span... it works perfectly..
Thank you Norman...
Regards
Naresh Kalyan
Hi Naresh,
This Mahamuni from Dombivali Mumbai sudhanvammahamuni@gmail.com. Please go through following link, hope this will be helpful for you......
https://myengineeringworld.net/2014/03/add-text-in-autocad-using-excel-vba.html
This program is developed by Mr. Christos from Greece. He is very helpful and if he know the solution he will defiantly help you,  you will find his contact details on his website.
Mahamuni
Loop all objects
if(type=mtext)
end if
Thanks in advance
Loop all objects
if(type=mtext)
end if
Thanks in advance
