VBA Open File with Dialog Box failed in AutoCAD 2018
zhenliang.fu
zhenliang.fu
My code can be used before in old version and now it doesn’t work in AutoCAD 2018. I tried to modify it several times without success. Can anyone help? Thanks. @Anonymous Yuan
' Form1 Code
Private Sub cmdBrowser_Click()
Me.txtFile = GetFile("Open dwg", "Drawings (*.dwg)|*.dwg|All Files (*.*)|*.*")
End Sub
' Module1 Code
Public Declare PtrSafe Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" _
(LPOPENFILENAME As OPENFILENAME) As LongPtr
Public Declare PtrSafe Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" _
(pOpenfilename As OPENFILENAME) As LongPtr
Public Const OFN_PATHMUSTEXIST = &H800
Public Const OFN_FILEMUSTEXIST = &H1000
Public Const OFN_HIDEREADONLY = &H4
Public Type OPENFILENAME
lStructSize As Long
hwndOwner As LongPtr                      'Autocad 2018
hInstance As LongPtr                          'Autocad 2018
lpstrFilter As String
lpstrCustomFilter As String
nMaxCustFilter As Long
nFilterIndex As Long
lpstrFile As String
nMaxFile As Long
lpstrFileTitle As String
nMaxFileTitle As Long
lpstrInitialDir As String
lpstrTitle As String
flags As Long
nFileOffset As Integer
nFileExtension As Integer
lpstrDefExt As String
lCustData As Long
lpfnHook As LongPtr                       'Autocad 2018
lpTemplateName As String
End Type
Function GetFile(strTitle As String, strFilter As String, Optional strIniDir As String) As String
'On Error Resume Next
Dim FileName As String
Dim oFileBox As OPENFILENAME
With oFileBox
.lpstrTitle = strTitle
.lpstrInitialDir = strIniDir
.lStructSize = Len(oFileBox)
.hwndOwner = ThisDrawing.HWND
.flags = OFN_PATHMUSTEXIST Or OFN_FILEMUSTEXIST Or OFN_HIDEREADONLY
.lpstrFile = String$(255, 0)
.nMaxFile = 255
.lpstrFileTitle = String$(255, 0)
.nMaxFileTitle = 255
.lpstrFilter = strFilter
.nFilterIndex = 1
End With
lntFile = GetOpenFileName(oFileBox)
If lntFile <> 0 Then
FileName = Left(oFileBox.lpstrFile, InStr(oFileBox.lpstrFile, vbNullChar) - 1)
GetFile = FileName
Else
GetFile = ""
End Function
The result is lntFile = 0so don't open File with Dialog Box...
Norman_Yuan
I am no sure where you got your code, but there have been a few different versions of it around thisor other AutoCAD discussion forums.
I recently just responded another question on this. Here is the one I posted in this forum a few years back:
https://forums.autodesk.com/t5/vba/old-vba-32-bit-does-not-run-on-new-64-bit/td-p/8391555
However, after that I did a couple of minor code change/modification. So, I now re-post the code (which has comment at top to indicate I am not the orignal one who created the code as whole), so to benefit anyone who may still focus on AutoCAD 64-bit VBA programming:
'' Following code is copied from Autodesk discussion forum here:
'' http://forums.autodesk.com/t5/inventor-customization/folder-browser-needed-for-vba-7-64-bit/m-p/4365989#M45667
Option Explicit
Private Declare PtrSafe Function GetOpenFileName Lib "comdlg32.dll" Alias _
        "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
Private Declare PtrSafe Function GetSaveFileName Lib "comdlg32.dll" Alias _
        "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long
Private Declare PtrSafe Function SHBrowseForFolder Lib "shell32.dll" Alias _
        "SHBrowseForFolderA" (lpBrowseInfo As BrowseInfo) As Long
Private Declare PtrSafe Function SHGetPathFromIDList Lib "shell32.dll" _
        (ByVal pidList As LongPtr, ByVal lpBuffer As String) As Long
Public Declare PtrSafe Function SendMessageA Lib "user32" _
        (ByVal Hwnd As LongPtr, ByVal wMsg As Long, _
        ByVal wParam As LongPtr, lParam As Any) As LongPtr
Private Declare PtrSafe Sub CoTaskMemFree Lib "ole32.dll" (ByVal hMem As LongPtr)
Private Const BIF_RETURNONLYFSDIRS As Long = 1
Private Const CSIDL_DRIVES As Long = &H11
Private Const WM_USER As Long = &H400
Private Const MAX_PATH As Long = 260            '// message from browser
Private Const BFFM_INITIALIZED As Long = 1
Private Const BFFM_SELCHANGED As Long = 2
Private Const BFFM_VALIDATEFAILEDA As Long = 3  '// lParam:szPath ret:1(cont),0(EndDialog)
Private Const BFFM_VALIDATEFAILEDW As Long = 4  '// lParam:wzPath ret:1(cont),0(EndDialog)
Private Const BFFM_IUNKNOWN As Long = 5         '// provides IUnknown to client. lParam: IUnknown*
'// messages to browser
Private Const BFFM_SETSTATUSTEXTA As Long = WM_USER + 100
Private Const BFFM_ENABLEOK As Long = WM_USER + 101
Private Const BFFM_SETSELECTIONA As Long = WM_USER + 102
Private Const BFFM_SETSELECTIONW As Long = WM_USER + 103
Private Const BFFM_SETSTATUSTEXTW As Long = WM_USER + 104
Private Const BFFM_SETOKTEXT As Long = WM_USER + 105 '// Unicode only
Private Const BFFM_SETEXPANDED As Long = WM_USER + 106 '// Unicode only
Public Const OFN_ALLOWMULTISELECT As Long = &H200
Public Const OFN_CREATEPROMPT As Long = &H2000
Public Const OFN_ENABLEHOOK As Long = &H20
Public Const OFN_ENABLETEMPLATE As Long = &H40
Public Const OFN_ENABLETEMPLATEHANDLE As Long = &H80
Public Const OFN_EXPLORER As Long = &H80000
Public Const OFN_EXTENSIONDIFFERENT As Long = &H400
Public Const OFN_FILEMUSTEXIST As Long = &H1000
Public Const OFN_HIDEREADONLY As Long = &H4
Public Const OFN_LONGNAMES As Long = &H200000
Public Const OFN_NOCHANGEDIR As Long = &H8
Public Const OFN_NODEREFERENCELINKS As Long = &H100000
Public Const OFN_NOLONGNAMES As Long = &H40000
Public Const OFN_NONETWORKBUTTON As Long = &H20000
Public Const OFN_NOREADONLYRETURN As Long = &H8000& '*see comments
Public Const OFN_NOTESTFILECREATE As Long = &H10000
Public Const OFN_NOVALIDATE As Long = &H100
Public Const OFN_OVERWRITEPROMPT As Long = &H2
Public Const OFN_PATHMUSTEXIST As Long = &H800
Public Const OFN_READONLY As Long = &H1
Public Const OFN_SHAREAWARE As Long = &H4000
Public Const OFN_SHAREFALLTHROUGH As Long = 2
Public Const OFN_SHAREWARN As Long = 0
Public Const OFN_SHARENOWARN As Long = 1
Public Const OFN_SHOWHELP As Long = &H10
Public Const OFN_ENABLESIZING As Long = &H800000
Public Const OFS_MAXPATHNAME As Long = 260
'OFS_FILE_OPEN_FLAGS:
Public Const OFS_FILE_OPEN_FLAGS = OFN_EXPLORER Or _
             OFN_LONGNAMES Or _
             OFN_CREATEPROMPT Or _
Private Type OPENFILENAME
    lStructSize As Long
    hWndOwner As LongPtr
    lpstrFile As String
    nMaxFile As Long
    flags As Long
    lCustData As Long
    lpfnHook As LongPtr
End Type
Public Type BrowseInfo
    pIDLRoot As LongPtr
    pszDisplayName As String
    lpszTitle As String
    ulFlags As Long
    lpfnCallback As LongPtr
    lParam As LongPtr
    iImage As Long
End Type
'====== File Browsers for 64 bit VBA 7 ========
Public Function FileBrowseOpen( _
    ByVal sInitFolder As String, _
    ByVal sTitle As String, _
    ByVal sFilter As String, _
    ByVal nFilterIndex As Integer, _
    Optional ByVal multiSelect = False) As String
    Dim OpenFile As OPENFILENAME
    Dim lReturn As Long
    sInitFolder = CorrectPath(sInitFolder)
    OpenFile.lpstrInitialDir = sInitFolder
    ' Swap filter separator for api separator
    sFilter = Replace(sFilter, "|", Chr(0))
    OpenFile.lpstrFilter = sFilter
    OpenFile.nFilterIndex = nFilterIndex
    OpenFile.lpstrTitle = sTitle
    OpenFile.hWndOwner = 0
    OpenFile.lpstrFile = String(257, 0)
    OpenFile.nMaxFile = LenB(OpenFile.lpstrFile) - 1
    OpenFile.lStructSize = LenB(OpenFile)
    OpenFile.lpstrFileTitle = OpenFile.lpstrFile
    OpenFile.nMaxFileTitle = OpenFile.nMaxFile
    If Not multiSelect Then
        OpenFile.flags = 0
    Else
        OpenFile.flags = OFS_FILE_OPEN_FLAGS + OFN_ALLOWMULTISELECT
    lReturn = GetOpenFileName(OpenFile)
    If lReturn = 0 Then
        FileBrowseOpen = ""
    Else
        If multiSelect Then
            Dim str As String
            str = Trim(Replace(Trim(OpenFile.lpstrFile), vbNullChar, ","))
            Dim ed As String
            ed = Mid(str, Len(str))
            While (ed = ",")
                str = Trim(Left(str, Len(str) - 1))
            Wend
            FileBrowseOpen = str
        Else
            FileBrowseOpen = Trim(Left(OpenFile.lpstrFile, InStr(1, OpenFile.lpstrFile, vbNullChar) - 1))
End Function
Public Function GetFiles( _
    ByVal nFilterIndex As Integer) As String()
    Dim strReturn As String
    strReturn = FileBrowseOpen(sInitFolder, sTitle, sFilter, nFilterIndex, True)
    GetFiles = Split(strReturn, ",")
End Function
Public Function FileBrowseSave( _
    ByVal sDefaultFilename As String, _
    Optional ByVal overwritePrompt = False) As String
    Dim PadCount As Integer
    Dim lReturn As Long
    OpenFile.nFilterIndex = 1
    PadCount = 260 - Len(sDefaultFilename)
    OpenFile.lpstrFile = sDefaultFilename & String(PadCount, Chr(0))
    'OpenFile.lpstrFile = String(257, 0)
    If Not IsMissing(overwritePrompt) And overwritePrompt Then
        OpenFile.flags = OFN_OVERWRITEPROMPT
    Else
        OpenFile.flags = 0
    lReturn = GetSaveFileName(OpenFile)
    If lReturn = 0 Then
        FileBrowseSave = ""
    Else
        FileBrowseSave = Trim(Left(OpenFile.lpstrFile, InStr(1, OpenFile.lpstrFile, vbNullChar) - 1))
End Function
'====== Folder Browser for 64 bit VBA 7 ========
Public Function FolderBrowse(ByVal sDialogTitle As String, ByVal sInitFolder As String) As String
    Dim ReturnPath As String
    Dim b(MAX_PATH) As Byte
    Dim pItem As Long
    Dim sFullPath As String
    Dim bi As BrowseInfo
    Dim ppidl As Long
    ' Note VBA windows and dialogs do not have an hWnd property.
    bi.hWndOwner = 0 'Windows Main Screen handle.
    ' SHGetSpecialFolderLocation bi.hWndOwner, CSIDL_DRIVES, ppidl
    bi.pIDLRoot = 0 'ppidl
    bi.pszDisplayName = VarPtr(b(0))
    bi.lpszTitle = sDialogTitle
    bi.ulFlags = BIF_RETURNONLYFSDIRS
    If FolderExists(sInitFolder) Then bi.lpfnCallback = PtrToFunction(AddressOf BFFCallback)
    bi.lParam = StrPtr(sInitFolder)
    pItem = SHBrowseForFolder(bi)
    If pItem Then ' Succeeded
        sFullPath = Space$(MAX_PATH)
        If SHGetPathFromIDList(pItem, sFullPath) Then
            ReturnPath = Left$(sFullPath, InStr(sFullPath, vbNullChar) - 1) ' Strip nulls
        CoTaskMemFree pItem
    If ReturnPath <> "" Then
        If Right$(ReturnPath, 1) <> "\" Then
            ReturnPath = ReturnPath & "\"
    FolderBrowse = ReturnPath
End Function
' typedef int (CALLBACK* BFFCALLBACK)(HWND hwnd, UINT uMsg, LPARAM lParam, LPARAM lpData);
Private Function BFFCallback( _
    ByVal Hwnd As LongPtr, ByVal uMsg As LongPtr, _
    ByVal lParam As LongPtr, ByVal sData As String) As LongPtr
    If uMsg = BFFM_INITIALIZED Then
        SendMessageA Hwnd, BFFM_SETSELECTIONA, True, ByVal sData
End Function
Private Function PtrToFunction(ByVal lFcnPtr As LongPtr) As LongPtr
    PtrToFunction = lFcnPtr
End Function
Private Function CorrectPath(ByVal sPath As String) As String
    If Right$(sPath, 1) = "\" Then
        If Len(sPath) > 3 Then sPath = Left$(sPath, Len(sPath) - 1) ' Strip backslash from non-root
    Else
        If Len(sPath) = 2 Then sPath = sPath & "\" ' Append backslash to root
    CorrectPath = sPath
End Function
Public Function FolderExists(ByVal sFolderName As String) As Boolean
    Dim att As Long
    att = GetAttr(sFolderName)
    If Err.Number = 0 Then
    FolderExists = True
    Else
    Err.Clear
    FolderExists = False
    On Error GoTo 0
End Function
 Here is the sample code to call Open/Save dialog and folder browse dialog:
Option Explicit
Public Sub TestOpen()
    Dim fName As String
    fName = FileBrowseSave("Test.dwg", "C:\Temp", "Save Drawing File", "AutoCAD Drawing (*.dwg)|*.dwg", 0, False)
End Sub
Public Sub TestSave()
    Dim fName As String
    fName = FileBrowseOpen("C:\Temp", "Open Drawing File", "AutoCAD Drawing (*.dwg)|*.dwg", 0, False)
End Sub
Public Sub TestFolder()
    Dim folder As String
    folder = FolderBrowse("Select Folder", "C:\Temp")
End Sub
The code works as expected with my Acad2020 and 2021, and should work with your Acad2018 (as long as it is 64-bit).
HTH
Norman Yuan
Drive CAD With Code
zhenliang.fu
Thanks for your quick reply. I have tested your code and can be used. Your supply code is too much so it takes time to understand for me. My original code was refer to the book about the VBA in AutoCAD, its characteristics is too simple, it would be very convenient if someone can modify it to be used. Finally, thank you for your reply.
zhenliang.fu
@Ed.Jobe Can you help how to do it?
Ed__Jobe
If Norman's code works, why not use it? We don't write long code just to make it longer. That's what it takes to use Windows api functions written in C++. You don't need to understand it (unless you want to learn C++). Just use what someone else has figured out for you.
True, it is a little longer because he gives you some other functions that might be useful to someone who needs to use the Windows api. Like FolderBrowse(). You can leave that out if you don't need to browse for a folder. But it isn't hurting anything to leave it there.
Ed
How to post your code.
