VBA Insert Block from Another Drawing
Hi all,
I am using the following method to insert autocad blocks into my drawing:
 Set objBRef = acadDoc.ModelSpace.InsertBlock(InsertionPt, DwgBlock, XYZScale, XYZScale, XYZScale, Rotation)
The program works fine when the block I want to insert is already included in the drawing.
I would like to know if it is possible to insert a block from a separate drawing.
I assume I replace 'DwgBlock' with the filepath/drawing.dwg I want to include but I cannot get it to work.
Help would be greatly apreciated.
Cheers,
Th1nkQuick.
Ed__Jobe
The method will only insert another dwg as a block. It will not find blocks defined in the external file. What you would have to do is first insert the external file and then delete the insert. This will bring in block def's, text and dim styles, etc. Then you can just insert the block by its name.
Ed
How to post your code.
Thank you eljobe. I have solved my issue after following your advice.
buianhtuan.cdt
Sub Sub4001_InsertTBLibrary()
'(VBA AutoCad) Insert TuanBui Library,[ITBL]
'Define Library FilePath
Dim Folder As String
Dim Filename As String
Dim FilePath As String
Folder = "C:\Users\buian\Desktop\TEST BRICS\02-INSERT NOTE"
Filename = "00-TBLIBRARY.dwg"
FilePath = Folder & "\" & Filename
'Check Exists file
Dim FSO As Object
Set FSO = CreateObject("Scripting.FileSystemObject")
If FSO.fileExists(FilePath) Then 'kiem tra trong thu muc co ton tai file k
Set FSO = Nothing
Else
Set FSO = Nothing
MsgBox "Please check File Path"
Exit Sub
'Insert
Dim ScaleMode As String: ScaleMode = "Scale"
'"Automatic","SelectPoint","Point00","DrawingOutside"
Dim InsertPointMode As String: InsertPointMode = "DrawingOutside"
Dim StrInsertPointX As Double
Dim StrInsertPointY As Double
Dim RotateAngle As Double
Dim DeleteExplode As String: DeleteExplode = "Explode"
'Define Pathname and blockname
Dim ExternalBlockname As String
ExternalBlockname = "UpdateBlock" & Func31HourMinute
Call HCF4003_InsertExternalDrawing(Thisdrawing, FilePath, ExternalBlockname, ScaleMode, InsertPointMode, StrInsertPointX, StrInsertPointY, RotateAngle, DeleteExplode)
End Sub
Sub Sub4002_A_InsertSurfaceTexture0()
'(VBA AutoCad) Insert Surface Texture Ra0,[RA0]
Dim BeginBlockname As String: BeginBlockname = "RA0_"
Call Func5012_InsertSurfaceTexture(BeginBlockname)
End Sub
Sub Sub4002_B_InsertSurfaceTexture25()
'(VBA AutoCad) Insert Surface Texture Ra25,[RA25]
Dim BeginBlockname As String: BeginBlockname = "RA25_"
End Sub
Sub Sub4002_C_InsertSurfaceTexture125()
'(VBA AutoCad) Insert Surface Texture Ra125,[RA125]
Dim BeginBlockname As String: BeginBlockname = "RA125_"
End Sub
Sub Sub4002_D_InsertSurfaceTexture63()
'(VBA AutoCad) Insert Surface Texture Ra63,[RA63]
Dim BeginBlockname As String: BeginBlockname = "RA63_"
End Sub
Sub Sub4002_E_InsertSurfaceTexture32()
'(VBA AutoCad) Insert Surface Texture Ra32,[RA32]
Dim BeginBlockname As String: BeginBlockname = "RA32_"
End Sub
Sub Sub4002_F_InsertSurfaceTexture16()
'(VBA AutoCad) Insert Surface Texture Ra16,[RA16]
Dim BeginBlockname As String: BeginBlockname = "RA16_"
End Sub
Function Func5011_GetInsertPointAndDirectionPoint() As Variant
'Select Insert Point and Direction Point
Dim InsertPoint As Variant
Dim DirectionPoint As Variant
Dim Result(0 To 1) As Variant
On Error GoTo Step1
InsertPoint = Thisdrawing.Utility.GetPoint(, "Select InsertPoint:")
DirectionPoint = Thisdrawing.Utility.GetPoint(InsertPoint, "Select DirectionPoint:")
Step1:
If Err Then
Result(0) = False
Func5011_GetInsertPointAndDirectionPoint = False
Else
Result(0) = InsertPoint
Result(1) = DirectionPoint
Func5011_GetInsertPointAndDirectionPoint = Result
End Function
Function Func5012_InsertSurfaceTexture(BeginBlockname As String)
'Get Dimscale and Define BlockScale
Dim DimScale As Integer
DimScale = Thisdrawing.GetVariable("DIMSCALE")
'Othor On
Thisdrawing.SetVariable "ORTHOMODE", 1
'Set UCS is World UCS
Dim Point00(0 To 2) As Double
Call FuncCadHome05SetUCSFromPoint(Point00)
'Select Insert Point and Direction Point and insert block
Dim Get2Point As Variant
Do
Get2Point = Func5011_GetInsertPointAndDirectionPoint
If VarType(Get2Point) = vbBoolean Then Exit Function
InsertPoint = Get2Point(0)
DirectionPoint = Get2Point(1)
Call Func5012_A_InsertSurfaceTexture(BeginBlockname, DimScale, InsertPoint, DirectionPoint)
Loop While VarType(Get2Point) <> vbBoolean
End Function
Function Func5012_A_InsertSurfaceTexture(BeginBlockname As String, DimScale As Integer, InsertPoint As Variant, DirectionPoint As Variant)
'Dim
Dim ObjBlockRef As AcadBlockReference
Dim XScale As Integer
Dim YScale As Integer
Dim ZScale As Integer
Dim RotationAngle As Double
Dim Blockname As String
Dim EndBlockname As String
XScale = DimScale
YScale = DimScale
ZScale = DimScale
'Define Blockname
Dim InsertPointX As Double
Dim InsertPointY As Double
Dim DirectionPointX As Double
Dim DirectionPointY As Double
InsertPointX = Round(InsertPoint(0), 2)
InsertPointY = Round(InsertPoint(1), 2)
DirectionPointX = Round(DirectionPoint(0), 2)
DirectionPointY = Round(DirectionPoint(1), 2)
If InsertPointX = DirectionPointX Then
'90,270
If DirectionPointY > InsertPointY Then
EndBlockname = "90"
Else
EndBlockname = "270"
Else
'0,180
If DirectionPointX > InsertPointX Then
EndBlockname = "0"
Else
EndBlockname = "180"
Blockname = BeginBlockname & EndBlockname
Set ObjBlockRef = Thisdrawing.ModelSpace.InsertBlock(InsertPoint, Blockname, XScale, YScale, ZScale, RotationAngle)
'Explode Block Reference
Dim ExplodeArr As Variant
ExplodeArr = ObjBlockRef.Explode
End Function
Function HCF4003_InsertExternalDrawing(Thisdrawing As AcadDocument, FilePath As String, Blockname As String, ScaleMode As String, InsertPointMode As String, StrInsertPointX As Variant, StrInsertPointY As Variant, RotateAngle As Double, DeleteExplode As String)
'Define PageSize
Dim TitleBlock As AcadBlockReference
Set TitleBlock = HCF4004_GetPartPropertyBlockRef(Thisdrawing)
Dim PaperSize As String
PaperSize = HCF4005_GetAttValueOfPartPropertyBlockRef(Thisdrawing, TitleBlock, "}–ʃTƒCƒY")
'Define InsertBlockScale from Dimscale and ScaleMode
Dim InsertBlockScale As Integer
InsertBlockScale = HCF4003_A_DefineInsertBlockScale(Thisdrawing, ScaleMode)
'Define InsertPoint
InsertPoint = HCF4003_B_DefineInsertPoint(Thisdrawing, PaperSize, InsertPointMode, StrInsertPointX, StrInsertPointY, InsertBlockScale)
'Define InsertPoint from PageSize,InsertPointMode,DimScale
Call HCF4003_C_InsertExternalDrawing(Thisdrawing, FilePath, Blockname, InsertPoint, InsertBlockScale, RotateAngle, DeleteExplode)
End Function
Function HCF4004_GetPartPropertyBlockRef(Thisdrawing As AcadDocument) As AcadBlockReference
'Call Function Unlock layer Frame
Call Func06UnlockLayer(Thisdrawing, FrameLayerName)
Dim ObjAttBlock As AcadSelectionSet
Set ObjAttBlock = Thisdrawing.SelectionSets.Add("objAttBlock" & Now)
Dim FT(3) As Integer
Dim FD(3) As Variant
FT(0) = -4: FD(0) = "<AND"
FT(1) = 0: FD(1) = "INSERT"
FT(2) = 2: FD(2) = PartPropertyBlock
FT(3) = -4: FD(3) = "AND>"
ObjAttBlock.Select acSelectionSetAll, , , FT, FD
If ObjAttBlock.Count = 0 Then
ObjAttBlock.Delete
Exit Function
For Each TitleBlock In ObjAttBlock
Set HCF4004_GetPartPropertyBlockRef = TitleBlock
Next
ObjAttBlock.Delete
'Call Function Lock Layer Frame
Call Func07LockLayer(Thisdrawing, FrameLayerName)
End Function
Function HCF4005_GetAttValueOfPartPropertyBlockRef(Thisdrawing As AcadDocument, TitleBlock As AcadBlockReference, TagName As String) As String
If TitleBlock Is Nothing Then
Exit Function
Dim varAttributes As Variant
Dim AttTextString As String
varAttributes = TitleBlock.GetAttributes
For i = LBound(varAttributes) To UBound(varAttributes)
If varAttributes(i).TagString = TagName Then
AttTextString = varAttributes(i).TextString
Next
HCF4005_GetAttValueOfPartPropertyBlockRef = AttTextString
End Function
Function HCF4003_A_DefineInsertBlockScale(Thisdrawing As AcadDocument, ScaleMode As String) As Integer
Select Case ScaleMode
Case "Scale"
InsertBlockScale = DimScale
Case "NoScale"
InsertBlockScale = 1
Case Else
End Select
HCF4003_A_DefineInsertBlockScale = InsertBlockScale
End Function
Function HCF4003_B_DefineInsertPoint(Thisdrawing As AcadDocument, PaperSize As String, InsertPointMode As String, StrInsertPointX As Variant, StrInsertPointY As Variant, InsertBlockScale As Integer) As Variant
'Define InsertPointMode from Excel
Select Case InsertPointMode
Case "Automatic"
If VarType(StrInsertPointX) <> vbDouble Or VarType(StrInsertPointY) <> vbDouble Then
InsertPointMode = "SelectPoint"
Select Case PaperSize
Case "A4"
Case "A3"
Case "A2"
Case Else
End Select
Case "SelectPoint"
Case "Point00"
Case "DrawingOutside"
If PaperSize = "" Then InsertPointMode = "SelectPoint"
Case Else
End Select
'Define InsertPoint
Dim BasicInsertPoint(0 To 2) As Double
Dim AfterInsertPoint(0 To 2) As Double
Dim SelectPoint As Variant
Case "Automatic"
AfterInsertPoint(0) = CDbl(StrInsertPointX) * InsertBlockScale
AfterInsertPoint(1) = CDbl(StrInsertPointY) * InsertBlockScale
Case "SelectPoint"
On Error GoTo next01
SelectPoint = Thisdrawing.Utility.GetPoint(, "Select Insert Point:")
AfterInsertPoint(0) = SelectPoint(0)
AfterInsertPoint(1) = SelectPoint(1)
next01:
If Err Then GoTo next02
next02:
Case "A4"
AfterInsertPoint(0) = A4X11 * InsertBlockScale
Case "A3"
AfterInsertPoint(0) = A3X11 * InsertBlockScale
Case "A2"
AfterInsertPoint(0) = A2X11 * InsertBlockScale
End Select
Case "Point00"
AfterInsertPoint(0) = 0
AfterInsertPoint(1) = 0
End Select
HCF4003_B_DefineInsertPoint = AfterInsertPoint
End Function
Function HCF4003_C_InsertExternalDrawing(Thisdrawing As AcadDocument, Pathname As String, Blockname As String, InsertPoint As Variant, InsertBlockScale As Integer, RotateAngle As Double, DeleteExplodeMode As String)
'Mode(Delete,Explode,Block)
'Add External Reference
Dim ObjExternalReference As AcadExternalReference
Dim Overlay As Boolean: Overlay = False
'Define XScale,YScale,ZScale
XScale = InsertBlockScale
YScale = InsertBlockScale
ZScale = InsertBlockScale
'Attach ObjExternalReference
Set ObjExternalReference = Thisdrawing.ModelSpace.AttachExternalReference(Pathname, Blockname, InsertPoint, XScale, YScale, ZScale, RotateAngle, False)
Thisdrawing.Blocks.Item(ObjExternalReference.Name).Bind True
'Explode Block,DeleteBlock
Dim ObjSelectSet As AcadSelectionSet
Dim EachObj As AcadEntity
Dim ObjBlock As AcadBlock
Set ObjSelectSet = Thisdrawing.SelectionSets.Add("ObjSelectSet" & Now)
FT(2) = 2: FD(2) = Blockname
ObjSelectSet.Select acSelectionSetAll, , , FT, FD
Set ObjBlockRef = ObjSelectSet.Item(0)
ObjSelectSet.Delete
Select Case DeleteExplodeMode
Case "Delete"
ObjBlockRef.Delete
Set ObjBlock = Thisdrawing.Blocks(Blockname)
ObjBlock.Delete
Case "Explode"
'Explode
Call HCF4007_ExplodeBlockReference(Thisdrawing, ObjBlockRef)
ObjBlock.Delete
Case "DeleteBlockRef"
ObjBlockRef.Delete
Case Else
End Select
End Function
Public Const LibraryPath As String = "C:\Users\buian\Desktop\TEST BRICS\TBLibrary"
'PageSize
Public Const A4X11 As Integer = 210
Public Const A3X11 As Integer = 420
Public Const A2X11 As Integer = 594
