VBA Collection
VBA Collection
grobnik
VBA Collection
grobnik
Hi to everybody, I'm trying to manage a Collection but I faced up a couple of issue that I'm not able to solve myself or with several documentation on web (mainly related to excel).
Here the code
Dim Coll As Collection
Set Coll = New Collection ' Create a Collection object.
For Each OBJECT In BSelSet
    Coll.Add OBJECT.Layer
    Coll.Add Str(OBJECT.Length / 1000)
Next
Source of Collection it's coming from a Selection set of Objects, working I get the objects.
First of all I would like to highlight that may I have duplicated layer name and duplicated length, this is the reason of two line with Add to member to collection.
So the Add Method using a Key that is the main reason using a collection seems not applicable.
As second issue seems I have some issue with storing number instead string.
The final scope will be to have a count of object with the same layer and same length (where layer name could be checked, but the length it's variable from object property), this is the reason because I would like to use Collection.
For Example:
Object 1 Layer "GREEN" length 100
Object 2 Layer "GREEN" length 100
Object 3 Layer "GREEN" length 150
Object 4 Layer "BLUE" length 200
Count Result:
 Layer BLUE Length 200 = 1
 Layer GREEN Length 100 = 2
 Layer GREEN Length 150 = 1
I tried also with Dictionary but I have the same issue of duplicated objects.
Third option will be use a bidimensional array and search (how I don't know, at this time) duplicated value and count it.
Thank you
norman.yuan
Well, you may need to "enhance your VBA coding knowledge, or in general programming knowledge, a bit more, by learning the concept of "class", which is a way to group different piece of data into a single unit. for example, AcadEntity, is a class that has many properties (or data fields), such as ObjectId, Layer, LineType, Color....
In your case, you are interested in particular information of entities in a selectionset. Let assume, you are interested in length and layers of all Lines and LwPolylines, and you use a selectionset with filter to select them. Then you want to collect all the length/layer data of each of the line/polyline and store them in a collection for later use.
To do this, you create a class to store data of each entity, and you create a collection class to store all of them. After that, you can use your data collected from the target entities. See code samples below:
1. the class to store data from individual entity, called MyEntity
Option Explicit
Public EntityId As LongPtr
Public LayerName As String
Public Length As Double
2. the class to store a collection of MyEntity, called MyEntities
Option Explicit
Private mEntities As Collection
Public Property Get Entities() As Collection
    Set Entities = mEntities
End Property
Public Function GetUniqueLayerNames() As Variant
    Dim ent As MyEntity
    Dim layers() As String
    Dim i As Integer
    If mEntities.Count >= 0 Then
        ReDim layers(0)
        Set ent = mEntities(1) '' Collection's index started from 1, not 0!!!
        layers(0) = ent.LayerName
        For Each ent In mEntities
            If IsLayerNameUnique(ent.LayerName, layers) Then
                ReDim Preserve layers(i)
                layers(i) = ent.LayerName
                i = i + 1
        Next
    GetUniqueLayerNames = layers
End Function
Public Function GetTotalLength() As Double
     Dim l As Double
     Dim ent As MyEntity
        l = l + ent.Length
     Next
     GetTotalLength = l
End Function
Private Function IsLayerNameUnique(layer As String, layers As Variant)
    Dim i As Integer
    If UBound(layers) >= 0 Then
        For i = 0 To UBound(layers)
            If UCase(layers(i)) = UCase(layer) Then
                IsLayerNameUnique = False
                Exit Function
        Next
    IsLayerNameUnique = True
End Function
Private Sub Class_Initialize()
    Set mEntities = New Collection
End Sub
this class has 2 methods to return a unique layer name list, and total length of all line and polyline. You can add more based on your business requirement,,,
3. Now it is time to use these 2 classes to collet data and do something (obtaining a layer names related to all selected line/polylines, calculating total length) and a MACRO module
Option Explicit
Public Sub DoWork()
    Dim ss As AcadSelectionSet
    On Error Resume Next
    Set ss = ThisDrawing.SelectionSets("mySS")
    If Err.Number <> 0 Then
        Set ss = ThisDrawing.SelectionSets.Add("mySS")
    '' Set filter to only select line, lwpolyline, or both
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = "LINE,LWPOLYLINE"
    ss.Select acSelectionSetAll, , , gpCode, dataValue
    '' populate the collection of MyEntities with the selectionset
    Dim entData As MyEntities
    Set entData = GetDataFromSelectionSet(ss)
    ss.Delete
    If entData.Entities.Count = 0 Then
        MsgBox "No line and/or polyline selected"
    Else
        Dim layers As String
        Dim l As Double
        layers = Join(entData.GetUniqueLayerNames, ", ")
        l = entData.GetTotalLength
        MsgBox "Layers: " & layers & vbCrLf & "Total length: " & l
End Sub
Private Function GetDataFromSelectionSet(ss As AcadSelectionSet) As MyEntities
    Dim ents As MyEntities
    Set ents = New MyEntities
    Dim ent As MyEntity
    Dim e As AcadEntity
    Dim line As AcadLine
    Dim pline As AcadLWPolyline
    Dim l As Double
    If ss.Count > 0 Then
        For Each e In ss
            If TypeOf e Is AcadLine Then
                Set line = e
                l = line.Length
            Else
                Set pline = e
                l = pline.Length
            Set ent = New MyEntity
            ent.LayerName = e.layer
            ent.Length = l
            ent.EntityId = e.ObjectId
            ents.Entities.Add ent, CStr(ent.EntityId)
        Next
    Set GetDataFromSelectionSet = ents
End Function
Hope this would give you some idea on how to use "class" to collect/organize data and use it in later process. The point is that one you get a well designed class and its collection, you can extract information from the collectionas you need, just as I did in the GetUniqueLayerNames()/GetTotalLength() for other business requirements.
Norman Yuan
Drive CAD With Code
grobnik
Hi @norman.yuan
thank you for lesson ! I'll try to applicate to my procedure, I'll keep you informed.
Your are right when saying "....general programming knowledge, a bit more, by learning the concept of "class" ...." I always said on this forum that programming it's not my job, even if I'm using cad often and many time I created macro for personal use, never for professional use.
All of what I know, and what sometimes I'm suggesting to others forum members, it's only a sort of "practice".
Bye and thank you again.
MakCADD
thank u norman,
I am also not a professional programmer
i learned programing through AutoCAD vba.
here you explained very well
thank s
