Copy/Paste, Duplicate, Offset, Mirror or Array path an Object (need help)
Message 1 of 1
Good day everyone,
I have an Object/Pline that has shape, I would like to make a duplicate of this object by following a conditions
1st. Select the Object to be copied (using get entity)
2nd. Select 2 points (getpoint) which is the path/length of this objects  to be aligned
3rd. It has different spacings
Spacing A= 2 pcs @ 50 mm
Spacing B= 5 pcs @ 100 mm
Spacing C= 5 pcs @ 150 mm
Spacing D= the rest  @ 250 mm
Both starting from left(Point1) and right(Point2), until they meet at the middle
here's some picture, the 1 green shape at the bottom is what I want to duplicate.
Select that object first, then select where it will be putted(corner to corner of columns)
any hints or codes might help me get start
Thank you
Replies (0)
