Public Sub ArrayRectangular
Dim RegionRoom As Variant
Dim RegionTile As Variant
Public numberOfRows As Long
Public NumberofColumns As Long
Public numberOfLevels As Long
Public distanceBwtnRows As Double
Public distanceBwtnColumns As Double
Public distanceBwtnLevels As Double
Public TileTo(0) As AcadEntity
Public Repeatearray As Integer
retObj = TileTo(0).ArrayRectangular(numberOfRows, NumberofColumns, numberOfLevels, distanceBwtnRows, distanceBwtnColumns, distanceBwtnLevels)
RegionTile = MyDWG.ModelSpace.AddRegion(retObj)
'Dim size of object based on Array Size
ReDim RetObjResize(0 To Repeatearray * numberOfRows * NumberofColumns - 1)
Dim ArrayN As Long
Dim X As Long
x = 1
For ArrayN = 1 To Repeatearray
' set Region to match poly object
RegionRoom = MyDWG.ModelSpace.AddRegion(RoomTo) 'Type: 3DSolid, Region
'Perform Boolean Method
RegionRoom(0).Boolean acIntersection, RegionTile(i)
Set RetObjResize(x) = MyDWG.ModelSpace.item(MyDWG.ModelSpace.Count - 1)
x = x + 1
Next
Dim i As Long
iCut = 1
For i = 0 To RegionCount - 1
Set obj = RetObjResize(i)
If TypeOf obj Is AcadRegion Then
Call PartsRequired(obj, Objarea)
Next
end sub
Attached partial code that first create array then perform intersection between 2 Region to find common points between 2 objects, then later i will loop through results to get coordinates
the code works perfectly, but my problem is that when Array =>5,000 going through loop become extremely slow
is there a way to do bulk operations instead of looping through each to perform Bollean method and looping through result to get coordinates ?
