Turning Layers on through VBA
Message 1 of 8
I have written VBA code in AutoCad that will open a certain drawing for the user, but I want it to turn on certain layers based on user input.  Let's say for this example I want to turn on the layer named "Walls".  How would I go about this?  The layer is off when the document is opened.  I'm sure this is a simple couple lines of code but I just can't seem to figure it out.
Replies (7)
Message 2 of 8
Ed__Jobe
If you're not concerned about viewport visibility, then its just like below.
    Dim oLay As AcadLayer
    For Each oLay In ThisDrawing.Layers
        If oLay.Name = "Walls" Then
            oLay.LayerOn = True
    Next
Ed
How to post your code.
Message 3 of 8
Looks like oLay is throwing an error. "Can't find project or library" not sure what is going on there.
Message 4 of 8
Ed__Jobe
Are you working in AutoCAD vba? You're not doing this from exel are you?
Here is a more efficient version. Although it could throw an error if "Walls" doesn't exist.
ThisDrawing.Layers("Walls").LayerOn = True
Ed
Message 5 of 8
grobnik
Hi @Anonymous @Ed__Jobe
If I have read well, the initial requirement was ".....based on user input....", and question is if would you like to have the same dialog "layer state" windows or a simple user form.
On the opposite @Anonymous accepted Ed solution so the starting request now falls.
I'm wrong ?
Bye
Message 6 of 8
That did it.  I am in AutoCad VBA not excel.
thanks for your help!
Message 7 of 8
I had it based on a userform, depending on what the user chooses in a drop box is what layer turns on.  I got it figured out now, sorry for marking the wrong solution I meant to just reply.
thanks!
Message 8 of 8
Ed__Jobe
The only thing I can think of is that it was a typo. Anyway, glad the second one helped.
Ed
