Storing Arraylist in System.Collections.ArrayList
mucip
mucip
I use System.Collections.ArrayList in my VBA code. I want to add one array to this Array like below:
Dim lateralListesi As Object
Dim i as integer
Set lateralListesi = CreateObject("System.Collections.ArrayList")
lateralListesi.add Array(pipeType, pipeLength)
After than add many pipeTypes I want to check pipeTypes in the lateralListesi. If I added same type in the lateralListesi before than I want to increase pipeLength only like pipeLength = pipeLength + newlyPipeLength
'I read pipeType before. and check if I added before?
For i = 0 To lateralListesi.Count - 1
            If lateralListesi.Item(i)(0) = pipeType Then
                'Early added.
                lateralListesi.Item(i) = Array(pipeType , Val(lateralListesi.Item(i)(1)) + newlyPipeLength)
            Else
                'Just new adding.
                lateralListesi.add Array(pipeType, newlyPipeLength)
        Next i
But I don't know why I cannot check inner array like ;
or
lateralListesi (i) (0)
Where am I wrong? I need two column temp table infact. I did not want to use dim and reDim. Because I don't know the row count in the begining.
Mucip:)
norman.yuan
Are you sure it is the line of code that does not work:
The following code sample works ok with my AutoCAD2020/2021 VBA, whether I use ArrayList(index), or ArrayList.Item(index):
Option Explicit
Public Sub Test()
    Dim arr As Object
    Set arr = CreateObject("System.Collections.ArrayList")
    arr.Add Array(1.11, 2.22)
    arr.Add Array(10.11, 20.22)
    Dim i As Integer
    Dim num1 As Double
    Dim num2 As Double
    For i = 0 To arr.Count - 1
        num1 = arr.item(i)(0)
        num2 = arr.item(i)(1)
        '' == following also works
        '' num1 = arr.item(i)(0)
        '' num2 = arr.item(i)(1)
        MsgBox "num1=" & num1 & vbCrLf & "num2=" & num2
    Next
End Sub
So, as long as you have legitimate ArrayList and enabled your AutoCAD that uses .NET framework 4.x to use legacy .NET 2.x runtime activation policy. That is, if you have not enable this, this line would raise error:
Norman Yuan
Drive CAD With Code
mucip
Dear @norman.yuan ,
arr.item(i)(0)= 25
I could not assign like this according to your sample:
arr.item(i) = array(25,15)
And I tyed below code and it worked I don't know why?
Mucip:)
mucip
Any feedback about this problem?
Mucip:)
