Set PLOT AREA and PAPER SIZE using WINDOW (via VBA or...)
12:09 PM
Hi
I want to type a command (for example 'windowplot') that asks me to set the plot area using option WINDOW.
The drawing will then by plotted via DWG to PDF:
1. on the correct paper size,
2. scale 1/1,
3. centered.
- The DWG to PDF.pc3 does have all the custom paper sizes we use, defined.
- I do not want to select the custom paper size, the command has to automatically select the right paper size.
So, 'windowplot' -> *select plot area* -> 'Ok' -> PDF pop's up at right paper size -> Save pdf as...
Any questions? Let me know!
Kind regards
MD
