Message 1 of 16
Select everything within a closed polyline?
11:25 PM
Is there a way to select everything within a closed polyline by simply
selecting the polyline?
(Please note: This is not the same as the cpolygon or wpolygon. You have
to pick each individual point for that command. I just want to select the
line.)
Jason gave me the following lisp file (see below), but I don't know Lisp, so
I'm trying to translate it to VBA. I can select the polyline with the
SelectOnScreen command, and can select every entity within the drawing, but
am unsure how to test if the entity is within the boundary.
Has this already been done or am I reinventing the wheel?
TIA, -Kirsten
Lisp file:
(defun C:Test ()
(ssget "wp" (massoc 10 (entget (car (entsel "\nselect polyline:")))))
(defun massoc (key alist / x nlist)
(foreach x alist
(if (eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
line.)
TIA, -Kirsten
Lisp file:
(defun C:Test ()
(foreach x alist
(reverse nlist)
