You have to place this code in a vba project and save it somewhere. At
the command prompt, type in "vbaide". When the ide pops up, click the
insert pulldown, then module. When the module window pops up, paste in
the code, then save and close out of the ide. Place the following code
in your toolbar button:
(defun c:TxtOver()(command "-vbarun"
"c:/mydirectory/myname.dvb!textoveride"));txtover;
where mydirectory is the location of where you saved to and myname is
the name you saved as
Then you should be all set to go.
-Josh
Amy Kauper wrote:
> do I have to put the ENTIRE code in the "macro associated with this button"
> area of the custom menu box? I got the "dimedit" to come up, but couldn't
> ever get it to override the "<>" I would've thought it would be simpler to
> get ACAD to type text for me?
> "Minkwitz Design" wrote in message
> news:3C88EF79.5090301@ameritech.net...
>>Hi Amy,
>>Yes. Your looking for the textoveride property of the acaddimension
>>object. Here's the code.
>>-Josh
>>Option Explicit
>>Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As
>>Integer
>>Function GetEnt() As AcadEntity
>>Dim ent As AcadEntity
>>Dim Pt As Variant
>>Set ent = Nothing
>>On Error Resume Next
>>Do
>> ThisDrawing.Utility.getentity ent, Pt, "Pick an Object :"
>> If Err Then
>> If GetAsyncKeyState(&H1B) Then
>> Err.Clear
>> Exit Do
>> ElseIf ThisDrawing.GetVariable("errno") = "7" Or
>>ThisDrawing.GetVariable("errno") = "52" Then
>> Err.Clear
>> End If
>> End If
>> If Not ent Is Nothing Then
>> Set GetEnt = ent
>> Exit Do
>> End If
>>Loop
>>End Function
>>Sub TextOveride()
>>Dim myDim As AcadDimension
>>Set ent = GetEnt
>>If TypeOf ent Is AcadDimension Then
>> Set myDim = ent
>> myDim.TextOverride = "EQ."
>>End If
>>End Sub
>>Amy Kauper wrote:
>>>Does anyone know how to write a macro that overrides dimensions from
> "<>" to
>>>say "EQ."???
