Select Blocks by its name
tramyer7mactavish
tramyer7mactavish
Hi Gents,
I would like to know how do i code like.
How do i select a cad by its name (code that finds a block name then select it)
I tried to code but it won't work.
Please see below my code kindly correct it as per your liking 🙂 because i know my code lacks of many things XD
Sub Test()
Dim block As AcadBlockReference
For Each block In ThisDrawing.ModelSpace
If block.Name = "justblock" Then
block.Select
than you and kind regards,
Tramyer
norman.yuan
1. About looping through ModelSpace.
Not everything in ModelSpace is AcadBlockReference. You need to only test block name if the entity is a block reference
2. About block name.
Unless you are absolutely sure you only are interested in static block (i.e. the block reference could be dynamic block), you better to use "EffectiveName" property, instead of "Name" property. Also when comparing name with literal string, you want to make the comparison not case-sensitive.
3. About "Select"
What do you mean "Select". In AutoCAD standard operation, it means certain entities are added into a memory group for particular operation the follows. AutoCAD highlight them in certain way in order for user to visibaly know which entity is included in the momery group (SelectionSet).
Now that you are writing code to let AutoCAD do something, depending what you want to do, you can gather certain entities into a group (such as AcadSelectionSet), and do things with the selection set with or without highlighting these entities.
Let's assume here you only want to HIGHLIGHT block refernece with given name, so, you can simply call Highlight() method, pretending the block reference is "selected" visibly. If the code of finding blcok reference with given name is to do something right away, such as move the found blocks, re-scale them..., there is probably no need to highlight them. So you really need to know what "select" really means to your process.
Here is the code:
Dim ent as AcadEntity
For Each ent in ThisDrawing.ModelSpace
    If TypeOf ent Is AcadBlockReference Then
        Set block=ent
        If UCase(block.EffectiveName)="THE_BLOCK" Then
            block.Highlight true
Next
Well, if you highlighted some entities, you may want to unhighlight them at certain point of time (user can also execute "REGEN" command to get rid of the highlight).
Norman Yuan
Drive CAD With Code
