Select all model space dimensions
Is there code for selecting all the dimensions in model space?
I want to essentially replicate what happens when I use qselect and grab all of the dimensions. Once I have the dimensions selected I want to:
(1) change their layer to my "DIMENSION" layer and (2) change their dimension style to my "ModelSpaceDimensionStyle"
Sure, use a filtered selection set. Entity type is specified by code 0 and
the entity is "DIMENSION", then for Model/Paperspace the code is 67 and
modelspace value is 0.
wrote in message news:5255221@discussion.autodesk.com...
Sub SelectDim()
Dim Selection As AcadSelectionSet
Dim Dimension As AcadDimension
Dim FilterType(1) As Integer
Dim FilterData(1) As Variant
On Error Resume Next
Set Selection = ThisDrawing.SelectionSets.Item("ssDim")
If Err Then
Set Selection = ThisDrawing.SelectionSets.Add("ssDim")
Err.Clear
Else
Selection.Clear
FilterType(0) = 0
FilterData(0) = "DIMENSION"
FilterType(1) = 67
FilterData(1) = "0"
Selection.Select acSelectionSetAll, , , FilterType, FilterData
'Selection.SelectOnScreen FilterType, FilterData
For Each Dimension In Selection
Dimension.Layer = "DIMENSION"
Dimension.StyleName = "ModelSpaceDimensionStyle"
Next Dimension
End Sub
This works great. I actually added a line:
Dimension.TextColor = acWhite
Is there a way to change the dimension line and extension line colors also?
