"X' button on form
"X' button on form
"X' button on form
I useed the Userform_QueryClose to cancel my form.
But I am typical situation.I have a form1 ...if iclick OK on form1 it opens form2.
Now in my case ,If user clicks the'X' button of form1 the application should terminate.I tried using the same USerform_QueryClose to do that . But a wierd thing is happening...when I click OK also the application is getting terminated.
Is there smthg toget arnd this.
Avantika
can you post you .dvb file?
arcticad
If you have multiple windows opened from the same dvb file it will close all the active windows when you press the X. I normally just offset the user for to the left 10000 and then if i need to recall it I will set it back to the original position.
This only works if the forms are modless.
Then set the original user form active.
(defun botsbuildbots() (botsbuildbots))
