Script file doesnt act the same through Autocad version
nguyen.np
nguyen.np
Hi everyone.
I create script file via excel vba and then import to Autocad to do some tasks. But when I use that script file in other computer with different autoCad version, some case the result was not as I expected.
OSMODE 0
Color BYLAYER
PLINE 0,900 @0,122 @287,0 @0,-15 @Anonymous.61,10.61 @Anonymous.39,-54.39 @0,-4.4264 @-54.39,-54.39 @-10.61,10.61 @0,-15 0,900
Color RED
TEXT S acisots 20,961 25 0 PART1 (287x122)x4
ZOOM W 387,1072 -20,880
GROUP C *  387,1072 -20,880
OSMODE 167
 I think there are something wrong with absolute/relative coordinates. I tried to change in Snap Setting -> dynamic input, but the result did not get better. Anyone with idea to fix this problem?
Thanks!
Ed__Jobe
You can temporarily turn off running osnaps by setting OSMODE to 16384. You should use lisp to store the the current setting, then restore it after you're done.
(setq omode (getvar "OSMODE")
;;run your script
(setvar "OSMODE" omode)
Ed
How to post your code.
nguyen.np
After change OSMODE 0 to OSMODE 16384, it worked perfectly!
Thank you very much!
