PickfirstSelectionSet problem
Message 1 of 11
Consider the following:
Dim objSS as AcadSelectionSet
Set objSS = Thisdrawing.PickfirstSelectionSet
...rest of code
This runs fine in a drawing. I then open another drawing and run the code in
it, works fine.
Then I go back to the previous drawing and run it again....
I get an error:
Run-time error '2145320949 (8021000b)':
Calling method AddItems of interface IAcadSelectionSet failed
It's as though VBA is getting confused between the 2 open drawings.
Has anyone else encountered this? If so what did you do?
I also get a similar error (something,something... IAcadSelectionSet failed)
sometimes with regular on screen selections too.
TIA,
Chad.
Replies (10)
Message 2 of 11
Is the objSS variable local to a function or does it
have module-scope ? What does "...rest of code" do?
I just ran this simple test in multiple documents
(starting the macro using VL-VBARUN as well as with
vla-runmacro), and in both cases I have not seen
any problem like you have.
Public Sub Test()
Dim ss As AcadSelectionSet
Set ss = ThisDrawing.PickfirstSelectionSet
ss.SelectOnScreen
If ss.Count = 0 Then Exit Sub
Dim Ent As AcadEntity
For Each Ent In ss
Ent.Color = acRed
Next Ent
End Sub
What I can tell you, is that you probably should
not keep a global reference to a variable that is
assigned to the PickFirstSelectionSet property of
a document.
"Chad" wrote in message
news:A91DC03E8923A8E2918CC3EE912F3356@in.WebX.maYIadrTaRb...
> ...rest of code
in
> it, works fine.
> I get an error:
failed)
> TIA,
> Chad.
Message 3 of 11
Tony,
Thanks for taking the time to give it a go for me.
I ran the code below and still got the same result. I even unloaded all
other custom apps I had running.
I'm trying this on 2002. If at least one other person reading this could
give it a go, it would be appreciated.
If it's just me that's having the problem, I might try re-installing
AutoCAD.
Chad.
Message 4 of 11
ran Tony's code, runs like a top in 2ki
Chad wrote:
> Tony,
> AutoCAD.
> Thanks,
> Chad.
Message 5 of 11
works here, but just a2ki so maybe 2k2?
Message 6 of 11
news:DE54537D0355ACC659C05AE780777511@in.WebX.maYIadrTaRb...
What code is that?
Message 7 of 11
I tried it in 2002 also, and had no problem like this.
Can you tell me how you're starting the macro?
> Tony,
> AutoCAD.
> Thanks,
> Chad.
Message 8 of 11
don't know if this is related but after trying your (tony's) code several
times on several dwgs, I closed acad and came back in through a shortcut on
my desktop which has a .dvb I've been working on as a startup file - that is
in the Target box I have this: "C:\Program Files\ACAD2000\acad.exe"
"C:\0\vb\pieceticket\rect411.dvb"
Acad tried to start then bombed and I got a ms c++ error - abnormal program
termination(or something like that)
I thought, oh no, what have I done now. I tried it several times and each
time the same thing.
I was getting really worried then tried a shortcut without the dvb start
file and it opened ok.
Then tried the dvb shortie again and still no go, then I took the dvb line
out of the target box and it started okay, then I put the dvb line back in
the target and alls well again.
So how's that for weird???
"Tony Tanzillo" wrote in message
Message 9 of 11
ps, I was running the code from vbaide.
after reading about your using vl-vbarun, i went to acad to make a
toolbutton to call the sub
and while making the toolbar button and setting the macro something happened
and acad crashed---thats why I had to come back into it with the
shortcut...and that's when all hell broke loose...
Message 10 of 11
Whooops, I removed it by mistake.
The code I was referring to was your sample as posted earlier
and I am running it from the Macros run dialog, and still no go.
This is really bizare. I think after everyone elses results I might
re-install.
Chad.
news:43F63648140FB99EC7BA41075760F3E3@in.WebX.maYIadrTaRb...
> What code is that?
Message 11 of 11
I think I have found a workaround and am curious if this will work in general or just in our specific case.
It appears in my case that having an object selected and then opening a drawing from the file/open menu but then cancelling out of it causes the count field in PickFirstSelectionSet to get corrupted.
So what I did was capture the runtime error that gets thrown when PickFirstSelectionSet gets corrupted and have this in my error handling code.
Dim sSets As AcadSelectionSets
Set sSets = ThisDrawing.SelectionSets
sSets.Item("PICKFIRST").Delete
ThisDrawing.PickFirstSelectionSet
What is weird is that not only does this delete the corrupted PickFirstSelectionSet, but it magically gets recreated immediately with the correct count field and all the correct objects that were in there originally. I am not sure how it can repopulate itself but I guess when it gets deleted and created again it goes through the drawing and repopulates itself with any selected objects.
If you try this let me the result as I am curious if it works on other systems. We are running AC 2007.
Paul
