Iterate thru block and it's nested blocks
mohandis2
mohandis2
I want to iterate thru a selected block reference, change the layer and color of it's entities, if a nested blocks found, iterate thru the same way and change the layer and color of it's entities.
Can anyone help?
Ed__Jobe
Here's my sub:
Public Sub BlockEntsByLayer()
    Dim oblk As AcadBlock
    Dim oBlk1 As AcadBlock
    Dim oBlkRef As AcadBlockReference
    Dim oBlkRef1 As AcadBlockReference
    Dim oEnt As AcadEntity
    Dim oEnt1 As AcadEntity
    Dim SS As AcadSelectionSet
    Set SS = GetSS_BlockFilter 'search this forum for this sub.
    For Each oBlkRef In SS
        Set oblk = ThisDrawing.Blocks(oBlkRef.Name)
        If Not oblk.IsXRef Then
            For Each oEnt In oblk
                If TypeOf oEnt Is AcadBlockReference Then
                    Set oBlkRef1 = oEnt
                    Set oBlk1 = ThisDrawing.Blocks(oBlkRef1.Name)
                    For Each oEnt1 In oBlk1
                        With oEnt1
                            If Not ThisDrawing.Layers(.Layer).Lock Then
                                .Layer = "0"
                                .color = acByLayer
                        End With
                    Next oEnt1
                Else
                    With oEnt
                            .Layer = "0"
                            .color = acByLayer
                    End With
            Next oEnt
    Next oBlkRef
    ThisDrawing.Regen acAllViewports
End Sub
Ed
How to post your code.
